  • Replies 52
yea i know. i had my doubts.
time for a 3540 and some cams al :down:
Honestly do not go a 3540, unless you get it extremely cheap, and go for the GTRS, it's a lot better.
Or speak to Vic about the turbo he wants to put on a 25; he has been discussing turbine combos with Kyp at ATP.
