sup
my car has been posted in here before when my brother owned it..but i got it off him a few months back for a sweet deal. here is my baby.
93 R32 GTS25
factory sunroof
2.5" full system and extractors
walboro 500hp fuel pump
ECU remap
lowered springs and shocks
17" Rays Engineering Silver Arrow rims
ive had so many people come up to me telling me that R32's didnt come from factory with RB25DE's, so many people.i just say to them well my VIN plates dont lie, unless some one went to the trouble of changing them without me knowing...ir the numbers 2500 that are on my rocker cover MUST mean 2000.idiots haha
sorry its a bit dirty in these pics....i washed it the next day
let me know what ya think
thanks but pleather is cheaper and looks the same :)
im thinking about getting plates anyone think URENMY (your enemy) is a good plate and would it suit?
um im chasing something i duno yet lol im not sure i like chromies but then again there to much of a hassle
Edited by DaveGTS4
Yeah R32s with RB25DEs had no VCT and the engine looked basically like an RB20 (cam cover looks the same etc, very silimar) whereas R33 and up RB25DEs had VCT and an extra lump in the cam cover, different spark plug cover, different plenum etc :(
Eug was that commented at me? If so, looking for wheels that won't break the bank and are not ricer (no chrome).
yeah it was mate, i have a few lying around which i'm looking to offload although the distance to send might cost some coin.
wow 370GT - don’t know much about them - There like the business end of the skyline family, sporty – but have a posh like sophistication to them - so it can be fun and erratic - but when it needs to be it can be quite and inconspicuous. Unlike the r32, 33, 34 that demand attention all the time just with their unique presence lol (I’m still trying to get out of HSC English mode so the bullshit is running through my veins :P so don’t mind me I’m just venting heheh)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
