sup
my car has been posted in here before when my brother owned it..but i got it off him a few months back for a sweet deal. here is my baby.
93 R32 GTS25
factory sunroof
2.5" full system and extractors
walboro 500hp fuel pump
ECU remap
lowered springs and shocks
17" Rays Engineering Silver Arrow rims
ive had so many people come up to me telling me that R32's didnt come from factory with RB25DE's, so many people.i just say to them well my VIN plates dont lie, unless some one went to the trouble of changing them without me knowing...ir the numbers 2500 that are on my rocker cover MUST mean 2000.idiots haha
sorry its a bit dirty in these pics....i washed it the next day
let me know what ya think
thanks but pleather is cheaper and looks the same :)
im thinking about getting plates anyone think URENMY (your enemy) is a good plate and would it suit?
um im chasing something i duno yet lol im not sure i like chromies but then again there to much of a hassle
Edited by DaveGTS4
Yeah R32s with RB25DEs had no VCT and the engine looked basically like an RB20 (cam cover looks the same etc, very silimar) whereas R33 and up RB25DEs had VCT and an extra lump in the cam cover, different spark plug cover, different plenum etc :(
Eug was that commented at me? If so, looking for wheels that won't break the bank and are not ricer (no chrome).
yeah it was mate, i have a few lying around which i'm looking to offload although the distance to send might cost some coin.
wow 370GT - don’t know much about them - There like the business end of the skyline family, sporty – but have a posh like sophistication to them - so it can be fun and erratic - but when it needs to be it can be quite and inconspicuous. Unlike the r32, 33, 34 that demand attention all the time just with their unique presence lol (I’m still trying to get out of HSC English mode so the bullshit is running through my veins :P so don’t mind me I’m just venting heheh)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
