I was thinking about painting the mags (powder coated) metallic black and leaving the outer lip polished aluminum, what do u guys reckon?
Edited by R34 -_-
Hey luke,
How much difference does a half cage make?
Does the chassis feel tighter?
Does it help much with going sideways?
Where are the mounting points on a 4door?
Is it very difficult for passengers to get in and out of now?
Did you have to chop much of the interior trim?
Edited by GTS4WD
Hey luke,
Hey mate,
Chassis feels alot stiffer with next to no body roll. When jaking the car up from the rear tow hook it raises evenly. I only do grip (4wd) but out on track steering is very responsive. I had to drill holes to mount it in. mounting points are on the rear wheel arches, right behind the drivers seat near the door and in the front on the floor. I just leave my back seat out, roof lining stays in, sunvisors come out.
Cheers Luke
Hey mate,
Cheers Luke
Thankjs for the reply,
So does the extra stiffness out weigh the added weight?
Ive removed sound deadening, A/C, heaps of shit behind the dash so i should still be below the factory weight.
Wanna get it on a weigh bridge and see how much it is. Later on will be fibre/cf doors, bonnet, boot etc but not for awhile.
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
