  • 3 weeks later...
Not a skyline but here we go anyway.
At the Drags. Unfortunately for me, the clutch was slipping on takeoff so i couldnt launch it......2500rpm and slip out was my only option :(
Ran 15.017 @ 97.22MPH, my 60" was 2.348 so with my brass button clutch coming soon i'll run it again. Unigroup have said the car should run a 14.5 with that MPH if i get a good clutch and some good tyres :D.
Only mods are twin 2.5" Catbacks, Pod Filter & Underdrive Crank Pulley. Will be putting in a SAFC soon aswell as some Kumho Ku36's ;)
when i first got it
wheels and a catback
impul sides and rear (sorry about bad quality)
nothing too special but alot of work has been put into that paint!
my latest effort at detailing it :)
next steps will be new suspension set up, gt-t brake calipers, brake pads, and hopefully a new front bumper and bonnet, then followed with a high flow cat and MAYBE extractors although the cost of thats probably not worth it but i want to get the most I can out of this car without spending a fortune! may eventually get it tuned as well if thats worth it.
*edit* cannon has now been changed to an oval muffler - sounds a fair bit better :)
Edited by Jonno34
when i first got it
Considering a NIS-Tune myself......, drop the car soon, 18inch weels on standard R34 suspension is to high.
^ 147rwkw sounds great for a n/a! more than enough power for me if I could get there
and definitely, sits incredibly high with 18s and stock suspension, my shockies are leaking too so thats my excuse to fork out the cash for new suspension :)
I emailed the workshop who did this R33 about four months ago and they said you could pick up an extra 30kW from the Nistune ECU (which is actually a modified Z32 ECU I believe). And in regards to your car, she sure is high! I don't even know what my suspension is, it's higher at the back though that's for sure. Once I get my 18" TE37s, I'll work on my suspension. Lol.
I was just browsing through the n/a forums in regards to the Nistune on an n/a 34 .. not too sure if it fits :\
long way to go yet before i worry about that though! suspension/brakes to do first and that will leave me broke for awhile ..
*edit* 30kw from a ECU + tune seems a bit unreasonable, most of the figures say around 10 or so .. probably isnt too much for the money
Edited by Jonno34
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
