The car has a gloss black vinyl wrap on the Bonnet, A pillars, Roof and C Pillars back, Carbon fiber look alike wrapped B pillars, as well as a black Series 2 boot and wing (it just dosent show up very well in photos), The pod filter is mounted to the chassis using a bracket and has a CAI directly beneath it as shown in the pics. Also has the compulsary ridiculasly loud aftermarket exhaust, a set of TEIN HA coilovers and a full set of blue nolathane bushes :)
I know its not the quickest car in a straight line, but its mine and untill im off my P's this will satisfy my love of shiny things lol
Edited by Nikk_666
joker's r34 i was making fun of the carbon fiber on your dash and usb stick but then i saw it on the ambi pur and just lost it. i have the same ambi pur and laughed so hard and all is well insted of poking fun im goin to say job well done.
:cheers:
Hey everyone, i just bought this 1995 R33 GTS, pretty much stock apart from ROH rims. thoughts??
Looks in good nik, i highly suggest your restore the headlights look around at the methods there are kits you can get or use very fine Sandpaper to get it clear again. Stock is the way to go keep it like that just play around with Height, Rims and Exhaust !!!.
MY 95 R33 SKYLINE N/A (CURRENTLY IMPOUNDED) WAS MY DAILY FOR THE 5 DAYS I MANAGED TO HANG ONTO IT
AND MY 96 180SX TYPE X SHELL RUNNING A SR20DE, MY CURRENT DAILY
Edited by IMPORTS ONLY
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
