Hey,
What kind of flywheel comes with the clutch? Also what else will i need to get this clutch going on my car except the $700 rebuild? Could you please tell me the name/location of the place that will rebuild it.
If all is good I am very interested.
Please email pics to [email protected]
Thanx
Evan
P.S. your mailbox is full
it has a steel flywheel very light stalls very easly
place fro the rebuild was in blacktown somwhere and that was quoted 12 months ago when i took it of my r33
pete
other things you would need for this kit would be a car preferably with a manual gearbox to stick it in
this should be good
finally have a pic of the apexi boost guage
it does light up green pink blue and other shit
here is the pik so everybody now knows i wasnt trying to pull a shifty and its there really is a nice boost guage
first in best dressed
pete
0409226626
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
