ummm..
1. convert to manual
2. drive it ;)
oh and doesn't risbey compliance em for ya? oh and also make sure you ask him about the taxes (that you pay on the car when purchasing) that youre supposed to get refunded once the car is deregistered in japan to be shipped OS
You could ask mr risbey himself, he's on the forums.
Guest RedLineGTR
Probably get it serviced...general stuff like oil, coolant, brakes, gear box oil etc. Thoe the importer usally does some of those thing i rather make sure they are done. Also you may want to pop it on a dyno for a quick run to check what power it is making and to see if everything A/F ratios are okay..maybe get the timing checked and ajusted to our fuels.
Put a massive Greddy sticker on the side; you know, the ones with three oblique gauges, a couple of neons under it and just pimp about...
/apologizes for stupid suggestions/
umm... just like what RedLineGTR suggested; full service then don't modify it; just enjoy it and learn the car for a few weeks...
yes i agree with the other dudes drive the car dont be stupid in it just have a bit of a drive then when you get in the car and think to yourself i know its quick compared to other cars but it kinda feels slow to me then start to mod it performance wise. if that is what you want to do. most people like to make theirs faster but dont feel pressured if you want to keep it stock do it. in the mean time if you want to spend money on it whilst just driving and getting the feel maybe if you want it louder get a cat back exhaust, if you want induction noise put in a pod+partition. and 1 major thing get an alarm system, and get a decent one, you get what you pay for.... if the windows arent tinted tint them! dark as hell on the back legal limit on the front tint the rear as dark as physically possible.....
;) g/l with the car :)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
