Damn thats right I forgot about the v-band. That turbo is a beauty. Ben Ellis at Otomoto gave me some info I liked. He said it will start boost around 2800 and makes 10psi at 3500. He said it will happily support 300whp. $770 US shipped is really cheap for such a turbo. Looks like no screamer or open wastegate for me. Thanks for replies.
MAKE SURE YOU GET A MONEY BACK GUARANTEE.....
Don't believe everything a sales person tells you :D
In my option, they are a cheap shit turbo and are VERY laggy for the power they produce.
300whp=220wkw
You will be much better off finding a HKS GT2530 or GT2535; or a Garrett equivalent.
True but I'm looking for a direct bolt on to factory mani. Just something that will put down 300whp efficiently. If someone can modify the stock mani to accept a wastegate that will work too. I'm not trying to spend 500+ on a mani with those power levels.
The turbos i mentioned are direct bolt ons, to the factory manifolds. The HKS turbos can come as a complete kit, so you don't have to spend more money on water/oil lines, dump pipes, intake pipes, fmic piping, etc.
Why go external gate on such a low power goal? Better to keep it internal, when you consider epa, defects, etc.
going with the KKR and custom or just off the shelf lines will still work out heaps cheaper than an HKS turbo kit.
alot of people dont like them because failures have been well documented. ive never used one so i cant speak from experience. a ball bearing garret unit isnt much more expensive.
a mate had the 430 on his RB20 cefiro with a microtech ecu. it was tuned very rich and made 210rwkw on 20psi. far from massive power but 220 is definetly achieveable.
theres also no reason why you cant have an external gate. alot of guys in nz use external gates on the original manifold. the 430 is more than big enough to utilise an external.
our 180 has a TD05 16g, a fairly small turbo with a monster trust external gate.....
plus external gates sound very cool.
goodluck. :down:
I would want even that response in writing, ive tuned a few, and havnt found the response or boost threashold to be great.
Don't believe everything a sales person tells you :cheers:
300whp=220wkw
+1
90% or more of reports show people NOT happy with these turbos after purchase.
+1
Thanks for responses. I'm now considering a gt30r or a tdo6-20g(If I desired more power its there). I don't mind a bit/alot more lag(save gas off boost :thumbsup: ). I want an external because I would trust it better than an internal and like esky_mad said it sounds cool. Nothing sounds like an external wastegate opening at 20psi. This car is just something to have a blast in. If I like it, I like whether its function or form.
Edited by twofortyrida
maybe also look at a GT28RS/GT2530/GCG RB25 High-Flow.. should get you around the power figure u want with supporting mods =]
But will they pull to 8k? Again no reason for 8k other than thats where I want to take it. I was looking at a GT3076R. Will it bolt to stock mani with a spacer? I need some more info on the tdo6-20g as well. Whats its efficiently range?
Not 100% sure if they pull to 8K someone else would have to clarify on that one, i just know their the most responsive/low amount of lag turbo's that are direct bolt on for an RB20 that pull hard early (no v-band required just oil/water lines would most likely need to be changed) and they reach about the 230rwkw mark. Good luck on the hunt =]
Edited by cosmokram3r
Thanks man. I want to go ahead to get a turbo efficient to 20lbs or so. I want a 17-20lbs from 4000-4500 to 8k or more. My ka just would run out of steam too early for me because of rpm limitations.
do you have an SR20? either way I am running a trust T518Z on my SR20 it's currently making 226rwkw on about 16/17psi (from memory). pulls very hard and comes on very nicely. great little turbo.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
