  • Replies 192
im intrested in the drift pineapples also are the front lower control arms (ball joints..all bolts etc) in good nicK?? no damage?? PM me the prices and postage for just the pineapples and price for the lowercontrol arms to victoria 3150 cheers mate tom 0401035221
selling the suspension with the pinapples and bushes sorry mate.
front left lower conrol arm is bent from the crash.
cheers,
Michael
UPDATED PARTS LEFT
momo steering wheel with boss kit - $70
speco boost guage - $10
roof handels - $5
hose clamps (10) - free
foot rest - $5
glove box - $5
ac unit - $50
centre console with white hand brake lever - $30
seat belt set - $20
interior plastic around rear quater and side windows - $10 all bits
kick panels - $10 ea
door trims - $20 ea
roof carpet - $20
dashboard - $5
bilstien suspension with sway bars and drift pinapples - $1200
gtr gearbox - $500
rb25det out of stagea (has sump with front diff gtr 4.11 gears) turbo, computer and loom - $1500
front right and left plastic mud guards - $10 ea
front windscreen plastic bit - $5
cheers,
Michael
don't wee all wish honestly if i had the readies would seriously consider your engine as you have 4.11 gears up front ;)
If they were salt and vinegar we would have a deal.. haha
Don't have the room anymore to store it.
interested could you get some pics of them
No worries. pm me your email address.
just note that the rears will fit gtst but the fronts will not
cheers,
Michael
UPDATED PARTS LEFT
roof handels - $5
foot rest - $5
glove box - $5
door trims - $20 ea
roof carpet - $20
dashboard - $5
gtr gearbox - $500
cheers,
Michael
  • 4 weeks later...
Hey mate.
Im looking for the front upper control arm nut and bolt that attatches the outside of the upper control arm to the strut assembly.
Still have it?
How much you want for it?
PM me!
Cheers mate
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
