Just wondering how much $ im lookin at about roughly for a full white respray, the cars already white just has sum fairly faded parts and ppl have keyed it and chipped bits off the paint off :banana: , i kno u pay extra if u want the inside of an an engine bay resprayed etc bt im jus lookin at the outside , as the inside doesnt need any at all.
cheers
Alex
https://www.sau.com.au/forums/topic/216867-respray-costs/
Price realy depends on work that is needed but as people have said that it will fall between 3/5k for a desent job .
the parts that effect prices are dents off cause windows been taken out if they have rubbers that are hard up againt the paint (some will say that this doesn't need to happen but this is why you see paint flaking in these area on skylines) how much work is needed to the front bumber before paint ,body kit will also cost more as well if a big one.
If its a basic white with a few scatches stone chips and a few shoppping dents that need to be done I would say around 3k from there the above will start to cost more .
Ps I am in Perth nth the river and do this for a living so if you need a quote advise or info feel free to pm me or come see me at my shop Pm for this as well if wanted .
https://www.sau.com.au/forums/topic/216867-respray-costs/#findComment-3831209
I think itd be good if we could get a rough price table or chart happening? Like how much you'd expect to pay for certain things. Example if you only needed your new front bar sprayed and what you could expect to pay depending on what prep work you had done.
This is hard as this all depends on the panel or bumber etc .
Fibre glass costs alot more than plastic second costs alot more than new.
Most places would charge about 400.00 for a plastic bar about 600 for the same in fibre glass .
This would apply for the bonnets as well about 400.00 steel in and out and between 400 to 1k for a fibre glass depending on work involved to prep .
As you can see I could go on for some time but what I am trying to say ther eis no real approx price as per say .
Colours also lay a factor as well in cost some colours can be done in 2 to 3 coats some take up to 5 which is nearly twice the colour some colours require 3 stages to reach the end colour .
PS people doing their own prep work can work out costing you more in the end as not many people prep well or use the right products this is best left to the person you want to do the job or with their advise so you are both going in the same direction
Edited by Xicon
https://www.sau.com.au/forums/topic/216867-respray-costs/#findComment-3831231
It depends on wha paints you get - Acrylic, Enamel, 2 pac in a solid, metallics or custom colour...
Its usually cheper to get the shop to buy them for you anyway, or are you just after an approx cost?
You gotta think of it like this:
Undercoat
Colour
Clear
you'll use approx 3-5L of each when spraying the car (depending on the thinners mix)
I purchased the paints for my 31 home respray at *almost* trade price from the local Auto1
total was about $700 for metallic 2pacs.
2pac undercoat ~ 5L + Hardener
quick dry 2pac enamel ~6L (3 colours)
2pac Clear ~ 5L + Hardener
2pac Thinners ~ 10L
All DeBeers paints.
Edited by B. J.
https://www.sau.com.au/forums/topic/216867-respray-costs/#findComment-3832107
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
