well i'll be turning up the boost slightly on my r33 with the usual stage one mods already done (full exhaust, front mount, pod etc) and before i do so i want to get a boost gauge installed.
now i was originaly thinking of going the DIN gauge pocket that holds 3 gauges under the stereo, but i only need the boost gauge, if i do go this way what other ones can i use? air/fuel ratio gauge? oil temp etc? are these others necessary?
someone suggested that installing gauges in that position is extremly difficult to wire up/connect.
so now im thinking of going A-Pillar gauge pod for 2 gauges....
where does everyone have there boost gauges (and any others for that matter) and where is the best place to buy gauges/pods from in sydney? (eg. autometer, sparco etc)
cant make up my mind lol
cheers
Something to keep in mind: Gauges on the A pillar will attract unwanted attention, not to mension its illegal to mount a guage (or anything really) above the dashboard.. well in NSW anyway not sure about the rest
BLITZ had a set of nice DEFI gauges or Sliding performance..
Cheers,
Apart from being a defect i think its great
Easier to view then the din guage!! biggest advantage esp if you are testing the car and want to know peak levels etc.. while driving the car at the same time..
Looks great too.. I havnt had any problems with cops etc..
i have seen them mounted in those mearcat gauge pods on the right side of the dash
just above the de-mister vent
easy to read and doesnt look out of place
which one is this? you got a pic
thanks
My boost gauge is mounted behind the steering wheel / boss kit. Sits nicely and well hidden from outside.
One of the best places IMO.
I had my boost guage there... Got to make sure that the vaccum line doesnt get crimped and show incorrect readings....
I like the autoworx pod..... doesnt it cut the airflow the windows bad, or have you not noticed any real difference?>
Ha! Yeah I made sure the hose was straight and no crimpes. It actually came like that when I bought it so not going to mess around with it. :laughing-smiley-014:
What about corners of the guage cluster? Just above the Air Conditioning unit?.. Like this:
I think that the A Pillar would give me the Mc Shits.. especially during cornering.. and if its at night the last thing you want is a bright light in your eyes as well
And if you want an idea for another gauge.. do you do track days of give your car a good pumping? get an oil temp one.. or got a big sterio? Volt meter?
that corner pod looks great
nah no track days or thrashings....
they do lok ok, maybe even the single pillar pod would be enough
im only running stage one mods, and nufin more ever, so theres no need to to get oil temp, water temp gauges etc etc
Why not keep stock boost gauge?
If you dont do trackdays.. or go requently for a spirited drive.. then a stock one will do fine..
Gauges are used because when you modify an engine it no longer works so you constantly cheak what the engine is doing..
If you dont have a heavily modified engine and dont push the engine for long periods of time.. stock gauges do fine..
Un-necessary gauges is another wanker thing to have..
yeh this is true, but if i want to run 10psi (which is where its at now im guessing with those mods) where is say 11 or 12psi on the stock gauge?
i know when it hits 7 on the stock gauge that is 14.5psi right? mine goes acouple of millimeters higher then the next line down (which is half way so around 7.25psi ?) so prob hitting 9ish psi giv or take
if i can get an acurate reading, then there is no need to go aftermarket gauge
if anyone knows how to read there boost gauge properly and has a pic and can mark where 10psi and 12psi should be, that'l be of good help
cheers
I've know a coupe of R33's which have been over the pits (in WA) with a Mearcat pod installed and was not an issue. Definitely not a defect in VIC. VicRoads documentation says you can have anything installed so it sits below the height of the steering wheel.
Although with the proliferation of GPS units, it makes me wonder whether they get fined?
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
