Polishing a rim for $30 a wheel? thats cheap.
Ussually most wheels have a paint attached, this needs to be stripped. Most often than not most dished wheels also have a clear coat on the lip or dish (even though its metal colour) this also needs to be stripped.
More often than not in NSW your looking at $80+ a rim.
Then more for painting if you wish to paint certain bits.
Chroming is quite expensive and I asked for my rocker covers, plenum, cooler pipes to be done I was quoted $750. Most chroming is done out of house at another company so this is why a higher price is charged. Turn around is about 2-3weeks from what I was told.
Edited by DECIM8
if you only want the lip done, take it to a place that repairs rims, they could just machine the lip then you can polish it yourself.
$80 a rim is normally to fix dents and repair - OR - change colour of the rim completely
yeh any wheel repair shop will be able to turn it on the lathe and polish it up for you.
on a side note, ive got bronze volk racing SE37's and i used a meguires rim 'spray and wash' cleaner, so i did my front drivers side rim, rinsed it off and its now left like a hazy white fog in some areas ! it said its suitable for aftermarket rims, clear coast safe bla bla
how do i clean this shit off !?
think Volk use annodising to colour their rims .. sounds like its started to etch the surface and remove the annodise :
check the MSDS of the exact wheel wash you used.
titanium lips are titanium, you would need a 3 piece wheel, then buy the outer lip section seperate in titanium.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
