Hi all,
Tonight adam (chefstagea) and I have got about 90% of his frount mount intercooler installed into his S2 stagea... Just got the last piece of piping to go and we have a slight question about it:
On the stock piping their was a small nipple with a black line going to it... Ive seen some intercooler kits which have these nipples on the new piping. Adams kit doesnt have the nipple on the piping. What does this nipple do? Im thinking ill go get one put into the piping while hes at work tomorrow. Where can I get the nipple installed? (exhaust shop maybe?)
the nipple I'm talking about is the one you can see here on the middle piece of piping:
Cheers,
Chris
https://www.sau.com.au/forums/topic/217176-frount-mount-intercooler-question/
On a series 2, you will need 2 nipples. One for boost and the other goes to the power steer pump.
I used a brass screw in nipple found at most auto parts shop. Drill a hole, and screw it in. The alloy pipes are fairly thin so I used some liquid metal approx $8 tube to fillet around the nipple and the pipe to make it stronger.
How to install nipple into a Intercooler pipe:
What you will need:
Brass threaded nipple fitting, with a 1/8 BSP tread on end (Sprint Auto $4.95)
1/8 BSP tap kit (from motortrader $37). This kit is needed as thread on nipple is a gas thread, thus it tapers
White plumbing tape
3mm Drill bit
8mm Drill bit
Heat silicon/sealent
Procedure:
Mark the spot that you would like the nipple with a scratch
Take 2mm drill bit a drill a pilot hole for the 8mm
Drill out hole with 8mm drill bit and more it around a bit to make room for tap
Tap 1/8 BSP thread into pipe
Place 2/3 layers of plumbing tape around the threads on the nipple
Screw nipple into piping and fastern firm but not over tight as intercooler piping is a bit soft could easily pull threads out
Place some heatsilicon/goop around bottom edges of nut on nipple just to ensure the seal is 110%
Happy days!
No finish Installing your frount mount intercooler, with one less thing to worry about :D
One more step, make sure you clean the inside of the pipe very well after to make such there is no metal bites from drilling. don't want them going thru the engine.
No need to buy expensive taps, as the thread is tapered it will cut it own thread, esp in the alloy pipe.
  • 10 months later...
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
