  • Replies 58
people come on... leave this poor guy alone so he can peacefully go off and spend BANGN's money on buying himself something else!
***EDITED PM OP FOR THE INFO***
thats just a kick in the guts...
* get someone to drop off parts to you rather than picking them up yourself
* not have the money ready there for that person
* say thanks for the parts but not pay
* then have the nerve to ask people on the same forum to help you out buying something else!!!
I was going to help this guy out getting a good deal but now after reading this I wouldn't give him SQUAT
+1
Guys,
As much as it seems clearly obvious to most people what has happened. As stated before, there is two sides to every story. At this point in time we have only one side of the story.
While I can see that people would rather be warned, please go about it using the correct procedures.
Defamatory remarks made towards businesses or individuals will not be tolerated on this website - We understand that if you have had a bad experience with a business you want to warn other people of said experience. Unfortunately, the same publicly expressed opinion could be viewed as libelous and/or constitute an attempt to deter business from any individual or business. Australian law holds the site owner partly responsible for any defamatory remarks posted on said website, and that is unacceptable. Informing people via PM's is tolerated as it is not a public message. With this said, feel free to post any information about a business or individual that you have had good dealings with.
if he is chinese
just tell him to buy a bowl of fried rice and sweet sour pork for all your troubles
then some how still wake up in the bushes
btw have you talked to your friend about it yet?
Edited by viet_boi
1. I did not request for you to leave the parts on my door. You did that on your own accord. I did not even request for you to come out to my place you were apparently in the area.
2. You were suppose to call me to arrange a time as to be home to meet you.
3. I have been in and out of Perth dealing with matters for work and it unfortunately put issues like this (although they are important) to the back of my mind. I also did the "I will deal with that when I get back to Perth" which unfortunately when you get back to Perth it slips your mind.
This does not excuse my lack of communication and I do apologise, it is not like me to neglect matters of this nature. Please send me your details and i shall deposit the cash tonight.
BTW thanks for the feeble threats however;
1. A member of the police cannot knock on my door for matters of this nature.
2. An individual of the police cannot knock on my door on days off etc to deal with matters that are not official. Friends or not.
k thnx bai
There will be no more explanation on my part on this matter and I am sure the other parties are in agreeance over this small matter that it best be left alone from here. As soon as I have the details it will be sent.
Closed.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
