  • Replies 58
people come on... leave this poor guy alone so he can peacefully go off and spend BANGN's money on buying himself something else!
***EDITED PM OP FOR THE INFO***
thats just a kick in the guts...
* get someone to drop off parts to you rather than picking them up yourself
* not have the money ready there for that person
* say thanks for the parts but not pay
* then have the nerve to ask people on the same forum to help you out buying something else!!!
I was going to help this guy out getting a good deal but now after reading this I wouldn't give him SQUAT
+1
Guys,
As much as it seems clearly obvious to most people what has happened. As stated before, there is two sides to every story. At this point in time we have only one side of the story.
While I can see that people would rather be warned, please go about it using the correct procedures.
Defamatory remarks made towards businesses or individuals will not be tolerated on this website - We understand that if you have had a bad experience with a business you want to warn other people of said experience. Unfortunately, the same publicly expressed opinion could be viewed as libelous and/or constitute an attempt to deter business from any individual or business. Australian law holds the site owner partly responsible for any defamatory remarks posted on said website, and that is unacceptable. Informing people via PM's is tolerated as it is not a public message. With this said, feel free to post any information about a business or individual that you have had good dealings with.
if he is chinese
just tell him to buy a bowl of fried rice and sweet sour pork for all your troubles
then some how still wake up in the bushes
btw have you talked to your friend about it yet?
Edited by viet_boi
1. I did not request for you to leave the parts on my door. You did that on your own accord. I did not even request for you to come out to my place you were apparently in the area.
2. You were suppose to call me to arrange a time as to be home to meet you.
3. I have been in and out of Perth dealing with matters for work and it unfortunately put issues like this (although they are important) to the back of my mind. I also did the "I will deal with that when I get back to Perth" which unfortunately when you get back to Perth it slips your mind.
This does not excuse my lack of communication and I do apologise, it is not like me to neglect matters of this nature. Please send me your details and i shall deposit the cash tonight.
BTW thanks for the feeble threats however;
1. A member of the police cannot knock on my door for matters of this nature.
2. An individual of the police cannot knock on my door on days off etc to deal with matters that are not official. Friends or not.
k thnx bai
There will be no more explanation on my part on this matter and I am sure the other parties are in agreeance over this small matter that it best be left alone from here. As soon as I have the details it will be sent.
Closed.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
