I am pleased to announce that this year's charity event will be an SAUWA member's event!
We will be raising funds for the Starlight Foundation with a Show and Shine Competition and a Poker Run.
UPDATE: Registration has now been opened up to non members - if you would like to come be sure to register as soon as you can - places are limited!!
WHEN: Saturday the 17th of May
TIME: 10.30am
WHERE: ***this information will be emailed once registration has been received***
WHAT TO BRING: A really shiny car
oker Run
ENTRY: $25 per team
TIME 11am for 11.30am departure
WHAT TO BRING: Full tank of fuel
Map Book
Teams (one team = one car) will navigate their own way to four ordered check-points.
At each checkpoint, team's will pick up an envelope containing a playing card. At the final checkpoint, the envelopes are opened and the team holding the best poker hand is declared the winner.
We have some prizes up for grabs! these are provided by our sponsors and will be given to...
- the show and shine winner
- the best poker hand
- the joker card holder
Important: All teams will need to pre-register by emailing the attached registration form to me (Lucy In The Sky) on [email protected].
I will print these forms and on the day of the cruise I will ask Team Leaders (drivers) to sign the declaration
sauwa_poker_run_registration.rtf
All proceeds from this event will be donated to the Starlight Foundation
This event is sponsored by
Edited by Lucy in the Sky
https://www.sau.com.au/forums/topic/217427-sauwa-poker-run/
  • Replies 85
hmmmm can dan the man bring my membership pack ? and how do i register ? i downloaded the form? and can i pay on the day?
Cheers
CHi
yeah chi it would be good if you came speak to lucy about registration maybe throw her a pm and yeah everyone is paying on the day
https://www.sau.com.au/forums/topic/217427-sauwa-poker-run/#findComment-3871823
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
