  • Replies 131
Any comments on the D-max from Racespec though? Whether it's gonna be the same or not?
we were a bit sus if the d-max gear that empire euro were legit, cos they look like they've been pulled from the mould a few too many times (like the edges of the guards weren't quite 90 degrees to the rest of the panel)... but they assure us that they are originals... and also they're not as wavy as the viva stuff... either way is still needed a high fill, sand and stuff to get it looking mint. couldn't comment on what racespec sells, never seen or used em.
I got the BN kit from BN Sports in japan, cost a fortune to bring over. Sold it below cost cos I never got around to fitting it (just wasn't a reasonable kit for a road going car). In the meantime we comissioned a company to copy my kit... we fitted a couple... but at the same time and they sold copies to other companies without us knowing... so there's a few getting around now.
Having flared guards without the wheels to fill them would look pretty strange and imo homo.
definatley agree with this, but when i got mine fitted i told the guys that i wanted them to sit out from the body just slightly and they would set it up for me. also wouldnt stretch tyres over.
i wanted it to look very similar to the white 33 with the flared gaurds earlier in the topic but was told they wouldnt do it!
who will do it, and cant spacers bring your rims out more?
peace
Gez
Well, I got my guards slightly flare today for $120.00 (only the two back ones) - quite plesaed with the result... however, now I will have to get fatter tyres and spaced them out a bit.
Does anyone know of a good profile for 18 inch rims on a R33? Cheers.
depends on your offset dude...
go pull a wheel off (or crawl under your car if its stock ride height :P )and it'll be stamped / stickered on the inside
peace
Gez
are you buying new rims?
its the offset not the setup...
you can use a spacer for a few mm but after that it becomes dangerous as the more spacer, the less thread...
the best way to do it is to use an offset calculator when getting new rims :P
someones been browsing zt.com :P
Yeah, I browse zt.com's wheel whore thread, but those weren't from zt. I stole the pics from zilvia.com's thread. :D
I always browse those two threads. Best two threads for wheel fitment info and pics. :D
pics?
did it affect/damage the paint at all?
hehe theres a build thread for that 32 in the body section, hickmaster r32 or something rather
Oh really? Thanks for letting me know, will check it out now...
Edit: This is his second 32 I think. He had a nice red onevia, sold it to get an R32, got over it, then bought I think it was an S14, then went back to the 32. haha. I remember asking him about his onevia's wheels specs, I didn't realise this was his car!
Okay, back to main topic.... :P
Edited by adam-__-
pics?
Just an update to all - I finally spent some cash and got brand new tyres today which set out a bit more to fill the guards - looks tough as in my opinion...
To answer your question, R-SPEC - only the lower edges of the arch had some paint flaking off, but i touchd it up with some paint and it's barely noticable... i would definltey recommend this, although it's not a big flare, it's definitely a noticable difference. awesome.
yeah already got some, they sit nicely with the body but still would like it to look a bit meaner lol.
how many mm do you think is too much? cause im looking at getting flared front fenders, only 30mm wider.
sorry about changing topic a bit btw.
cheers
Gez
Who did you end up getting it done by?
cheers
Gez
I would say that anything more than 10mm spacers are too much if you're looking at only slip ons. If they're bolt ons then I wouldn't really care as long as they're hub centric.
there is no way in hell you can safely run 30mm spacers...
i run 3mm on the fronts just to clear the calipers.
you will need either:
a custom unit
a bolt on set if there is one available
new wheels
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
