  • Replies 96
yeah its on this weekend, and watchers are welcome. just make sure you bring a gtr so i can steal bits when required lol. sunday is better as sat includes qualifying and scruitineering. and you will probably need to pay for entry
BTW.......I need an intake headlight for the new sports sedan....where did you get it, and do you mind if we make a mould from it?
i dont think my gtr is good for pilfering parts at the moment. but my garage.. well thats another story..
and i think brad wants to mould it too. or do something along them lines.
its made by http://www.silkroad-jp.com/section/hli.html
have you shared how you worked out the oil temp gauge problem mad scientist?
ROFLMAO,,,Yea come on buddy share. Nothing like taking the piss out of poor Duncan. Such good fun..
He will come good,,,we just have to wait. Happy days.
As a great man said "It's not my car".
Neil.
could be a chilly weekend thanks to the arsehole racing drivers club. $200 for a garage and they are all booked already by porsche drivers.
According to BOM
Saturday Mostly fine.
West: Min: 6 Max: 17
Sunday Chance shower.
West: Min: 7 Max: 17
looks like lovely 4wd turbo weather.
we need to get the pop off valve sorted this weekend too :)
BTW Brad I asked about our disagreement re the regs and the tech committee will get back to me. I will be happy if they agree with you :D I'd love a few more killer wasps or even better some less lag with those slow old turbos
Andrew id really like to borrow that headlight if you dont mind!!
Ill be out there on sunday so can pick it up from you then, Duncan you just want one of them??
I am getting a mould done of it and also a brake duct/intake mould too.
Duncan you know we're going to get an ammended rule book now with the loop holes fixed.
Also what form of boost controller are you actaully using Duncan??
You know that the form of controlling boost is free provided the pressure remains within the manufactures specs.
Jas - yes we will run a pop off valve on the weekend that will enforce 11psi (stock boost for r32 gtr). If anyone has nissan docs confirming that n1s had the rumoured 14psi it would be really damn helpful to me....
Jess - sorry, can't hear you :)
Brad - they only know I have a question, not that there are different "interpretations" out there. I want it clarified before I spend another 1k on poncams. And yes I got agreeement to run a boost controller (i have greddy prospec blah blah thingy) because the standard boost control is *very* unreliable. so at least if the valve keeps going off I can turn it down a bit. And I would love a copy of the headlight for the sports sedan :P
Looks like the suspension might be in afterall, Gary has been flat out putting it together and we are going to try and fit it all up tomorrow night, and wheel align at the track on Sat morning.
That only leaves the side pipes and suspension pickup adjustments as the only things I still need to do for the new rules. Then onto building the spare engine, and if nothing goes wrong (lol) it will all be pretty organised.
BTW I hear a rumour there will be a 400+rwkw gtr sport sedan running. If I didn't annoy them enough last weekend, I think a real one will this weekend :( will be interesting to see how it goes over a few laps - hope the have got some really nasty sticky slicks for it, about 325 wide would be nice
You'd like the original one? or would you like the section/silkroad number?? hopefully i can make it out on sunday,
as for boost control, get a large needle, and start poking thousands of holes in your accuator lines, and then pray it all holds together :D
lol I think that is what they are trying to get on top of Andrew.
We are on 3rd so about 10ish and 2ish each day probably. new shocks are in after 1am this morning (and thanks for providing the cold cold garage and help Neil :)), just needs a wheel alignment in the morning and off we go.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
