Hi. i have a R34 25GT-T with a GT30R with stock internals, i was wondering if it would be necesary to have a oil catch can with this setup or when is that you really need one in a rb25.
Im not planing to go over 20psi or over 7500 rpm
thanks
Giancarlo
https://www.sau.com.au/forums/topic/217628-catch-can-question/
A catch can always a good idea.
At taht level of boost if you are hitting redline and pedalling the throttle a lot you will begin to get blow by issues. A catch can will collect the oil vapour/mist that comes out of the roker cover breathers when you get off the throttle after full boost.
when you say blown by issues you mean oil coming out issues or other type of issues?
Yeah blow by is gases from combustion squeezing past the piston rings or past a cracked piston or ringland and pressurising the sump. This will cause oil to be sucked into your turbo if your oil breathers are connected to your intake (factory setup). If you start getting alot of blow by, oil will begin to leak out of the BOV if you have an aftermarket one and out the oil filter and possibly the dipstick.
Basically just hook up a catch can to stop any oil vapour from being re-circulated through your intake system.
Ok in a catch can reconected to the block, everytime i lift the gas the vacum will suck all the oil back to the engine preventing any leak or blowing?
From my understanding of a catch can, its to catch all the oil fumes so it does not go into the air intake.
Then you gota empty it out and all this yuck claggy shit come out of the can.
And I think you might have to do a bit more of a regular oil top up.
I had one but the previous owner did not pipe it correctly and had a hose from the catch can leading out to the atmosphre and oil was basicaly evaporating out.
Unless for race applications, I don't think you need it.
So it allows your engine to 'breath', sorta...
If it's installed correctly, it's actually an oil-air separator. As the oil-vapour laden air passes into the canister, the oil condenses out, leaving just "clean" air to continue on to the induction side.
Cool thanks!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
