in regards to the above you tube links.
im not real sure what you guys see in the gtrs.
have you not been in anything faster?
it makes lots of wooshing noises but dosent seem to pull very hard.
you may say im full of shit but i know what my wifes car is capable of and that gtrs has nothing on the muppet bus.
i think the car above in question has lots of mods and a hell of a lot of money thrown at it , yet it struggles to make the wheels chirp as it ramps onto boost in second. wheres all the midrange? for dollars spent it should spin to the limiter when you floor it in second, but it dosent.
have you driven that car cos it sounds like you know the person or how it drives or are you just guessing
i found your muppet bus
its as fast as you say it is well done you must know what your doing .......take EG MEMBERS
just in case you did not like that one
nice set up
moving right along !! lol
Edited by WARLORD
  • Replies 50
Yeah thats a fairly good point, if thats in 2rd - mine gets a lot more savage than that and romps through second. Makes the pretty noises too, but probably a fair bit cheaper setup - and only running conservative boost.
The GT2835 vid posted in this thread sounds like it'd give it a spank :D
Heres a clip with mine when I got the internally gated housing, before I got the boost controller for it:
http://www.youtube.com/watch?v=1tajFNv_q7Y
when you ran the 1/4 in that video on you tube it looks like you ran a mid 13 ,do you remember what you ran. :thumbsup:
1) the car is the vid is running a 2835 pro s (the gtrs was mentioned later)
2) people go for this setup as they are able to get away without forgies
3) how do you know he floored it?
Answer: It's a very nice streetable turbo that is capable of pushing out 250-260rwkw
Answer: Yes, I have. What's your point?
Answer: How do you know the amount of boost he is running, or what modifications for that fact? How do you know he even floored it? The curve on this turbo is much more linear, thus, it won't appear to smash you to your seat like a larger turbine would.
Answer: As for your muppet bus, I don't feel as though I need to say anything......... The video explained it all :thumbsup:
Answer: He could've been running 9 PSI for all you know, maybe he has 265 tyres on the rear? Maybe he has an awesome suspension setup? Maybe he didn't floor it?
Please don't come on this forum and insult peoples' cars and what mods they have. The GT-RS is a great turbo and I'm sure all those people who have been in a car with that turbo will agree with me.
Cheers
Hi guys,
Just thought I might share my video with ya'll. Went for a drive this morning (nice and cold), got up to about 200km/h.
Have alot of traction issues in 1st and 2nd gear, sometimes even third if you smash the gears in.
What do you guys think, not bad acceleration?
cheers
Nice results, seems to go very well, just a question, what tyre/sizes are you using? seems like your are using a cheap tyre thats not very wide, hence not very good traction, im using 255 toyos and i have full traction in 1st (trys to spin up 2nd if you shift fast enough)
Cheers
Mate, this thread should pack it in.
Why post a speedo vid, could have been going down a hill for all we know.
Everyone knows the 2835 is a bloody top turbo so now lets see some 1/4 times.
End of story.
Hey thanks for the comment.
I'm using 235's and they are bridgestone, not sure what model and CBF checking.
What's the thickest tyre do you think I could put on 7.5" wide rims? Could I go 245?
I'm looking for 17 x 7.5 on the front and 17 x 8.5 on the rear but no one sells such rims for a cheap price these days. Any recommendations? I know Work sell them but they are like $2,400 JUST for the wheels themselves!
End of story.
Pretty hard to get such wheel spin going down hill if you ask me?? :thumbsup:
And no, I wasn't going down hill. :D
245 on that rim not a problem ..people put 255 m/t on 300zx rims which are 7.5.
Yeah Ive got some 235/45s on a 7" rim sitting in my garage, so 245s shouldnt be a prob on a 7.5...only thing is they roll around on the rim and gives the car a squishy feeling as the sidewalls move around a bit more..
Cheers
Andrew
when you ran the 1/4 in that video on you tube it looks like you ran a mid 13 ,do you remember what you ran. :)
13.3 @ 112mph :) I'd post a time slip but its a huge pic. That was done with no boost controller it was effectively boost creeping, until it finally reached 1bar and it would stabilise a bit. I needed to be well into 3rd before it reached 1bar of boost, so first gear was no/hardly quicker than with a stock turbo (running 11psi pretty much) and then built up from there. By 3rd is was starting to stomp. Since then I have put an AVCR in it and the comparison is night and day from back then - on the dyno it makes pretty much no peak power difference, just that in first and second it all comes in and the midrange feels WAY better. It was also lagging a bit on each gear shift prior to the boost controller :(
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
