hey ppls
ive got me some hks frontpipes im about to install, just wondering though if i need to get heat wrap for them ? i tried using the stock frontpipes heatshield but that doesnt fit. should i just slap them on and not worry about any heatshield type thing ??
what do most ppl do ?
thanks
https://www.sau.com.au/forums/topic/217783-gtr-frontpipes-heatshield/
sif not consult me on such a minuscule topic...what is this world coming to :D
I say do it, that heat wrap stuff if done properly works really well. One of the big ground air supply machines at work has that stuff wrapped round all the exhaust pipes and the pipe of the turbo is only just warm when it's going full pelt and less heat in the engine bay is always a good thing! I wouldn't think twice about doing it on mine if I had it all out. Anyway I know you've got plenty of moulah to waste :down:
to late, couldnt be stuffed waiting for people to reply so i just slapped em on :down:
bloody getting the gaskets to defy gravity was an issue.
I say do it, that heat wrap stuff if done properly works really well. One of the big ground air supply machines at work has that stuff wrapped round all the exhaust pipes and the pipe of the turbo is only just warm when it's going full pelt and less heat in the engine bay is always a good thing! I wouldn't think twice about doing it on mine if I had it all out. Anyway I know you've got plenty of moulah to waste :P
to late, couldnt be stuffed waiting for people to reply so i just slapped em on :(
little smear of CRC Maniseal is your friend :)
holds them in place nicely
i heat wrapped my Trust front pipes and passenger floor still gets unbearably hot.
Edited by DiRTgarage
to late, couldnt be stuffed waiting for people to reply so i just slapped em on :blink:
loss!
you've taken out the insulation haven't you :(
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
