hey guys
ive bought a rb26dett for my s15
the motor has spun a bearing so im rebuilding it before it goes into my car. the engine has
hks cams
hks cam gears
i want to make 400hp atw what do i need to do in my rebuild to make that power, and is the r33 gtr crank better than the r32 one? and also what turbos would be suitable for this with out lag.
cheers
https://www.sau.com.au/forums/topic/217884-building-a-rb26dett-for-400hp/
hey guys
hks cams
hks cam gears
cheers
forgies, preped standard rods, metal headgasket, good set of bearings, oil restricitor, freshened up head (new seals etc) set of hks gt-ss turbos.
hey guys
hks cams
hks cam gears
cheers
rebuilding an engine rarely is the thing that makes power, (other than head mods etc) forged pistons and rods etc dont make any more power they allow the engine to be more durable at higher power levels. A set of forged pistons, new bearings and rings, N1 oil pump, crank collar and a reco'd head is all you would need chasing 400hp. Id use HKS GT-SS's or 2860-7's for good low down grunt...with these turbo's id put stock cams back in it too and dial them in correctly with your cam gears.
if you want it built properly shoot me a PM or email
Edited by DiRTgarage
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
