went into morpowa again yesterday (nearly my 2nd home these days) spoke to a few lads there, and they have pointed me in the right direction with the next step on my 33.
the next step being after market ecu
they recommended power fc, as piggy back option is apparently not as tunable or flexible as a full upgrade ecu.
i ended up agreeing on the price of $2250 supplied, installed and dyno tuned.
cant complain really, seing as the ecu for the 33 has ceased production. (so i heard)
so it goes in tomorrow (thursday)
i cant wait,
speaking from experience, did the aftermarket ecu come up to your expectations?
and what step did you take from there?
cheers
craig
https://www.sau.com.au/forums/topic/218147-woohoo-i-got-power-fc/
  • Replies 59
good price.
i didnt buy a pfc, but my wallet is still empty. :down:
lol, i only got the money beacause the missus made me sell my bike..hmm...i have 3g left..... savings??? or engine work?? hmmmmm
its so hard lol
Nice buy! PFC is up next on my mod list too - just got a couple things coming up to get out the way first... girlfriend's birthday and anniversary - a month of each other :down: (replace internet explorer icon with my wallet)
Nice buy! PFC is up next on my mod list too - just got a couple things coming up to get out the way first... girlfriend's birthday and anniversary - a month of each other :bomb_ie: (replace internet explorer icon with my wallet)
lol, you better hurry up and get saving mate, from what i have heard, the distributer is really low on pfc for 33 gtst.
not bad!! but i got my pfc for 1500? and paid like 300 in tuning! it pays to know people
yeah that sounds about right, but they have gone up since they stopped making them, i paid 1650 fot the ecu itself, and 500 for install and tune, its not a bad price really, and i trust the guys down there, i havent had any trouble since i have been using them.
i only had mine done in the begining of this year
that is a bargain Adrian! (and a bloody good bargain if its an Rb25 under youre bonnet we're talking about?)
there are quite a few ECR33 PFCs still floating around for sale new and second hand. They are pretty easy to get your hands on as long as youre willing to spend anywhere from $1200 - $1700.
well done if you could find one for cheap, but i get very paranoid! if spending cost price + 100% mark up for the unit is what it takes for my peice of mind, then thats what ill spend.
and also, if theres any probs with the ecu...strait back to the factory for warrenty repair it goes...
now do you think its worth the extra few hundred dollars?
ahhh, this may soumd like a dumb question, but, where do they usually sit the hand unit in a 33??
i dont want it somwhere to obviouse where mr and mrs piggy will see it.
i put my pfc on the leftside of the steering column using the velcro patch supplied n run the cable behind and thru the glove box that way if u r worried bout the cops u can just put in the glove box
morpowa tuned my power fc n did a great job, the tune will be cheaper next because they wil save the maps on their laptop, they also tune the fc while its out on the road aswell 2 chek the knock levels
thanks danai!!!
you have exact the same set up as me with the ebc and tt, i like where you have your fc, i suppose it would be good to have in a visable spot, but move it quickly if need be....im glad to hear they did a good job of yours, ahhh knock sensor? what the? lol, i have no idea when it comes to japanese cars at the moment lol
cheers for that mate.
thanks danai!!!
on ya power fc u can display all sorts of readings, i display speed, revs, water temp, injector duty, timing and knock reading
the knock sensor reads small amounts of detonation and is displayed by using numbers, i think the most u want 2 see is no more than 60 (not sure) if u give it 2 much throttle and the detonation reads higher your engine warning light will flash, the knock reading can be reset on ya controller, mine doesnt get any higher than 12-25 on boost n about 7 off boost
^^^oooohhhhhh oookkkkk.....im sure ill pick these things up over time, ill be glad to get thew thing in and running right!!
will let ya know how it goes when i get it cack tomorrow, thanks again guys!
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
