1 question i have that im gona send an email away is if i get the v88 and i get it tuned for the neo motor and i put a different motor in like a 26 can i load a 26 map into it later and tune that or i have to get another ecu.
  • Replies 895
can anyone confirm that the v44 plugin will run low impedence injectors without using a resistor pack?
I have heard they from different people that they will but have also read you need a resistor pack.
Anyone done this yet?
Vipec V44 plug-in manual:
GTR models are fitted with LOW impedance injectors run via factory fitted ballast resistors. This ECU has been designed to be used with HIGH impedance (greater than 6 Ohms) injectors. Ballast resistors must be wired if low impedance injectors are to be used. This means that the ECU is plug-in compatible with factory fitted injector/ballast combinations on all models.
with the amp or with the figures in the knock map?
with the amp. i'm keen to know how people are setting up the knock response threshold since it's hard to know what knock sounds like for a given engine unless you can produce it. ie no point having the knock function set at a threshold such that the thing is rattling away but the ecu does nothing because the knock severity at which it acts only occurs when the conrod exits the block.
unless of course it's a noise filter like the Turbo XS Knocklight.
would also be nice if they could find a way to use the standard knock sensors on the GTR.
it uses the standard sensors, the plugin and the V44 need an amp/signal filter so that the input is 0-5v without much random signal noise where as the V88 has that built into the unit.
Scooby....
Ear muffs/det cans. :geek:
i know how you listen for knock, what i'm asking is how you set the knock correction point if you don't know what knock freqs are for a given engine.
if it was standard practice to get the engine to 'just' start knocking and set that as the threshold for the ecu to trigger knock control there would be no question, i just don't intend getting my car tuned that way.
Turbo XS claim that once the procedure of calibrating the Knocklight to the freq range of normal engine noise for a given engine - ie without knock - is complete, it recognises freqs outside that as knock. they are confident that the unit will pick it up correctly because knock freqs are fairly unique. in other words it detects freqs outside those parameters as knock, although the suggestion is that knock freq range is extremely narrow. i'm not advocating their approach but i can see it's plausible as they use the parameters of an particular engine's unique freqs.
another example; the stock GTR ecu has knock control but if you use it on an RB26/30, which will have a different knock freq to a stock RB26, there is no guarantee it will be effective as what it hears when a 26/30 knocks itself to death might be different to what it has been calibrated to recognise as knock.
hope that makes sense.
just not sure how it's done with the Vipec.
Edited by Scooby
With the vipec can you select high or low impedance injectors?
Also just wondering considering the current group buy on the Haltech E11V2 @ $1545
Why would you choose the Vi-pec over the Haltech?
Those who have the v44 whats your idle like? Now I have the injectors and hks turbo on, the idle seems to hunt a lot, where before it was almost flat as a tack? Is it worth doing some data logging?
your engine didnt eat turbo bits did it?...probably only a simple air leak though...are the injectors sealed where they seat on the head flange?
My engine may of eaten some small turbo bits, compression test came back regular no cylinder vastly different to the other., some small metal flakes were found around the intake and around the IM. Intercooler piping etc was all cleaned out. What do you mean by are the injectors sealed?
Wasn't doing this for the few mins I had the car idling after the turbo blew.That was with the old injectors
thx
My engine may of eaten some small turbo bits, compression test came back regular, some small metal flakes were found around the intake and around the IM. Intercooler piping etc was all cleaned out. What do you mean by are the injectors sealed?
thx
they have small rubber insulators that seal the injectors to the head...its quite common to not seat them correctly allowing a small amount of air to enter the system which is making the idle hunt.
Frankly I wouldn't know, I have the software to monitor the ecu, but I havent had the chance to use it.
edit: I'll have a look tomorrow to see what I can around the injectors, thx for the tip.
Will see if I can do some datalogging of the ecu on friday as well.
thx
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
