Hey all,
As title says its a dec 95 model Black manual, has done 83,000km's (imported with 73.500km's!! Basically driven to and from work only, bout 35km's a day) I am the first owner in aus. I have spent a lot of money on it since i got my liscence in feb, basically all mod's except for the air filter were put on by me since then. Oil changes every 3,000km's with Penzoil Race Synthetic with Penazene addative. Mods include:
-17*8" Gradu racing rims
-Custom ATP T03/4 turbo
-Custom AVO bar and plate front mounted intercooler with polished mandrel bent alloy piping, no welded joins (cooler polished aswell) and Hose Techniques blue silicon joins
-3" dump pipe off turbo to cat into a genuine 3" Fujitsubo LegalisR exhaust
-K&N M's high power air filter
-HKS turbo timer
-AUtometer ultra-lite pro comp gauges
-Custom alloy catch can all polished with braided fittings
-Razo race gear knob and Razo race pedals
-Custom dash switch panel covered in pearl white vinyl.
-Odyssey dry cell battery
-Nismo belt pads on all belts, and Nismo hand brake pad
-Pioneer head unit, front splits, 6*9's running off 600wAmp, boot wired ready for big sub set up, previously had a huge system in it, and have left all brand new cabling ready for new subs/amps. Also has false floor fitted with all panels and wheel well filled with dacron to kill dead sound and improve sound quality.
Just took some new photos, show its real beuty :P Also thought i'd add i have had the timing belt and all axilery belts changed, front urethane castor rod bushes and a new o2 sensor fitted so she is absolutely puuuuuuuuuurring!!. Also now has 12 months of reg to... so can't complain at all peoples!!
http://www.angelfire.com/co3/thegrub1/inde...dexskypics.html
If interested, and can meet in Melbourne to view.
https://www.sau.com.au/forums/topic/21822-nice-black-95-gtst/
anybody who is looking for a decent skyline would be stupid not to buy this car with the mods its got on it, for that price..
you're all stupid buyers out there :P
YBSLO4: you can slip me the $50 later :D
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
