Injection perfection (bankstown airport) seem to have a good rep. They quoted me $33 an injector, being cleaned in a bath, and then thru 1 of the pulsing machines. $33 seems abit steep?
Another place at lidcombe (search thru posts abotu cleaning) said $22 an injector.
Let me know how it goes. Im looking to do the same, though just waiting til i decide if im going to clean these, or replace with higher feed unit.
Thats like $190....???? I hope that includes flow testing and new o-rings etc. Ill try them on Monday.
Its strange the things that stick in your mind, i thought $8 (aprox) for ultrasonic cleaning was close to the mark, so maybe $33 is for flow testing and new o-rings etc?
I had mine done by Jamie Waterhouse (4721 7227) at peach tree... he did my whole 100,000km service (I supplyed the timing belt though) and I think it cost about $600 all up. Have the recipts somewhere but he has always met (or been VERY close to) his quotes and has also done a good job.
He once had my car for two days (Friday Arvo, Saturday and Sunday morning) looking for a problem with a miss... he eventually didn't find anything after spending most of the weekend on it (he usually only does half Saturday) and when he gave it back he said... I could not find the problem... (Pressure tested and flow tested and all sorts of things... even had the fuel pump out) when asked how much I owed him for his time he said "nothing... he didn't fix a thing."
I noticed that I got a much more smooth power delivery and it felt to me like I got a power gain. I had the injectors removed when they were cleaned.
I have also heard good reports about Nepean EFI and they are just off Batt street I think?
Yeah , I see your point Ben.
Flow and pattern testing , as I understand it means: Pressurize each injector, activate it, measure the flow (in cc's) and pattern (like does it dribble or is a nice spray) [yeak OK that is not a very technical explanation]
Cleaning is seperate -
No point cleaning a stuffed injector !
It included new O-rings and Plastic tips (whatever they are called) and were ultrasonically cleaned, and flow tested as well as checking the spray pattern.
Let me check the receipt when i get home for the name, i only know it as the blue building near the gym
As for differences in driving, ill never know, they are GTR injectors going into my Rb20, along with a new turbo and ECU. So was more a peace of mind thing for the new setup
Roy,
Did you get the results for each test on each injector - like on paper ?? Or did they just say 'yeah they are ok'
If the former, can you let me know where you got them done ??
I need to test 6 Hi Flow pieces of shit injectors - prolly they are still stock which would explain my smallish engine issue.... Anyway that's another story....
Thanks mate,
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
    • I do this, I also don't get the joke
    • Return flow cooler will be killing you I reckon. You can certainly push more through a low mount setup but they're good numbers for a stock looking engine bay.  Mine made 345rwkw (hub) at 22psi on 98 with a "highflow" on a stock manifold but it's a long way from a normal high flow or standard engine. I used one of those Turbosmart IWG-75's and it was great with the Motec running closed loop boost with pressure being applied to both sides of the diaphragm.
    • Hey man do you have pic of adaptor plate by any chance I need to match up the bolt holes as my gearbox adaptor plate ones are way off the only bolts of starter motor are matching thanks
