hey guys
As some of you may have already seen i am putting in a rb25 in my 32 with in the month or so.... now i am in the process of find who could help us out in fitting it for me as i am no where near qualified and i would want it done right haha
so if any knows of a good person/workshop to go to... or a place where you have been and wish to recommend, this would be greatly appreciated
thanks :blush:
Edited by wellzy
https://www.sau.com.au/forums/topic/218701-rb25-halfcut/
just found invoice
rb25motor and box: $3460
microtech lt10 ecu: $1320
hd organic clutch: $630
3 inch dump: $360
mufflers removed, micro tech wired in, box and motor install, clutch installed, removal of rb20det, dyno tuned: $ 900
pluss 667$ gst
made 250hp at 13psi
https://www.sau.com.au/forums/topic/218701-rb25-halfcut/#findComment-3857817
just found invoice
3 inch dump: $360
pluss 667$ gst
made 250hp at 13psi
thanks champ.... that helps me heaps
keep em coming guys :blush:
https://www.sau.com.au/forums/topic/218701-rb25-halfcut/#findComment-3857899
thanks for all the replys guys.... i will be contacting all of them and getting an idea of pricing...
im also thinking about asking ovaboost in malaga and kensei garage in wangara as i have dealt with them b4.... so ill see how we go, ill keep yous all posted
thanks again
https://www.sau.com.au/forums/topic/218701-rb25-halfcut/#findComment-3866369
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
