Traders on SAU/internet forums are the cheapest I've found - I told the guy at autobarn approximately $500 through SAU traders when they were selling them for about $1000 he replied SAU traders probably selling fakes... I lol'd.
haha same thing happend to me went to autobarn they said they could get power fc for 1650 and said i found 1 on the forums for 1100 and he said its prob a fake i also lol'd
wanna hear a funny story? my parents neighbour is a floor manager at one of the autobarn stores (better not name it)
just last week, he asked my old man to help him change his windscreen wipers cos he had no idea! lol
:D
hmmm even the most simplest of things are out of some peoples reach.
:P
and those people are supposed to have a reasonable knowledge on their products...... :laughing-smiley-014:
