G`DAY ALL,As we have been talking about meeting up once a month for a chat or what ever we set up.Then we need to get it HAPPENING so LETS GET IT GOING,PLease put up what you think is a good time ,where when,thank`s boy`s & girl`s,looking forward to seeing what`s what ,cheer`s chuckie
https://www.sau.com.au/forums/topic/218909-perth-stagea-owners-meet/
exhaust cam gear will bring the powerband down the rev range a bit, wont give you any gain in peak torque/power though.
oh yeah.. i'll invite myself along as the ritual non-stagea driving atendee. :laugh:
Edited by mungell
well depending on date etc - we should be there
lotty is going to melb in about 3 weeks- so thats when I am aiming to do my adj cam gear install
so just let me know hey
So, 3 weeks time at Seans place then?
Who is organising the strippers?
that would be nice :D I am not so keen on having to drive around WOT to get any power
oh yeah.. i'll invite myself along as the ritual non-stagea driving atendee. :)
well a mate did it to his r34 and he reckons boost comes on quicker and better mid range torque
I dont really like " winding it out " to get max power
hmmm an oppertunity to drink beer and drool over stageas im in to. shonky, what sort of gains are u expecting from your cam gear? im interested in maybe doing one also
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
