I have a track only R32 GTR and i can tell you it does make a difference. I have an APR adjustable wing and it can either be a help or a hinderence it does take time to get the set up right but it will be a benefit if you take the time to set it up.
I did a test with my engine builder who reckons there crap and do nothing, 2 laps at full angle seen him bouncing down the straights ( very funny ) 2 laps at no angle saw his over steering at every corner again very funny! and 2 laps at normal settings... i believe he now likes rear wings!
A few random thoughts;
The front undertray helps a lot with the cooling, I wouldn't leave them off for that reason alone. They increase the airflow though the intercooler and radiator by creating a partial vacuum under the engine bay. When we ran the R32GTR in Production Car racing it would overheat without the undertray.
"Add downforce" is a bit of a misrepresentation, more like "decrease the lift". Without the front undertray we were getting more lift at the front at anything over 100kph, I could see it on the shock sensors data log. The dogleg at Oran Park was a prime example, the air would get under the front and lift it up, put the undertray back on and that lift stopped.
After spending 2 seasons with the F3 and half a day with Frank Dernie (ex Williams, recently Toyota) I can positively say I don't know anywhere near enough about aerodynamics. But what I am confident in is that modifying the front standard undertray to fit an aftermarket front bar, with say aluminium extrensions, would not be a bad thing.
Cheers
Gary
Thanks for the info Sydneykid.
What undertray have you got in the R32gtr?
It's a Production Car so the standard undertray is it.
The R32GTST is built to the Improved Production regs so it has a flat undertray with a splitter out the front to the profile of the bumper. The regs only allow the undertray back to the front of the wheel arches.
If I had full freedom, I would simply copy a V8Supercar undertray which has a raised centre with votex generators.
Cheers
Gary
thanks for the Gary and others...
under body aero was what i was really keen on as well. I thought it might be more beneficial than putting a spoiler on it...
unfortunately with my front bumper, i had to take the middle factory undertray off :blink: as it had to where to attach to the East Bear front bumper...
But when i was looking at it, from the side, it looks like this...
|_____________ (front of car here)
And because the front edge had nothing secure to attach to (besides my bush mechanics)... it did this at high speeds...
|__
.....__
.........__
.............__
.................__ (ROAD contact followed by horrible noise)
And it just seemed like all it would do was act as like a parachute at the front?
As in, wouldn't it just create more drag when the air slams into the upright section??
If i were to get a full undertray, or just to the front of the front wheels, it wouldn't matter then if i didn't have the factory undertray?
Does it matter what a full body undertray is made out of??
someone want to lend me some money for these CF parts? i'll put your like workshop sticker on my car or something :blink:
i swear they had a front one too, but i can't find it....
R35 GTR
Sorry to hijack, but can anyone shed some light if the electronic front spoiler on most r32 gtst's do anything?
It pops out at 80km/h and was wondering if it actually helps?
My car also came with a c-west gt wing when first bought it, the rear of the car felt really unstable on the freeways haha, pulled if off and drives much better :blink: It was set on max angle and never bothered to play around with it :blink:
unfortunately with my front bumper, i had to take the middle factory undertray off :starwars: as it had to where to attach to the East Bear front bumper...
|__
.....__
.........__
.............__
A properly designed front undertray helps hold the front lip up off the ground. The idea of a front splitter/spoiler is to make the air go either over or around and NOT under.
The problem with underbody aero is that it depends on proximaty to the ground (that's why it's called "ground effect"). On a production style car (in comparison to a formula car) that's very difficult to achieve. A simple example, when you brake the rear goes up and loses the ground effect, hence you get trailing brake oversteer. Conversely when you accelerate the nose lifts, you lose front end ground effect and corner exit understeer can result. Don't think that you can fix this with exagerated spring rates either, a production chassis simply isn't rigid enough, production tyres have flex in the sidewalls and you lose so much mechanical grip (from the high spring rates) that the aero doesn't compensate.
That's why race cars have wings, sure they have some underbody tidying up, but the front spoiler and rear wing do more than 80% of the work from an aerodynamic viewpoint.
If they are available, carbon fibre is the go, whereas custom undertrays are often made out of aluminium sheet, 2 mm, 2.5 mm and 3 mm are common thicknesses depending on the size and load.
Cheers
Gary
I've been thinking about a new under tray for the front as mine was butchered in japan
Japanese: http://www.silkroad-jp.com/section/dif.html
translated: http://translate.google.com.au/translate?u...en&ie=UTF-8
Silkroad seem to make a nice unit.
and looking at top secret rear diffuser also. but i think they are more looking nice than anything.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
