  • Replies 63
No thanks..
I am looking at getting another similar for $200 but I have to wait a while for it, so I thought that I could get this one now for the same price..
All I can offer is $200 for the ECU, NO EXCHANGE
Well, I took the plunge and got a remapped ecu.
Picked toshi up after work and headed down to my mechanic to put it onto a dyno. I can only say good things both about toshi and the maps he's put together. I shall post the dyno sheets hopefully on monday, though on the first stock run ;
RWKW - 119
Torque - 546
AFR - 10.35
Speed - 119
After replacing the ecu with a remapped ecu from toshi, the results were ;
RWKW - 145
Torque - 631
AFR - 10.32
Speed - 111
So from the remap I gained another 26rwkw. I guess its still running very slighty rich, the rev range from say 3.5k to 5k is 10x better, so much more throw back. We played with timing alittle, though we started loosing power from 20c+ so we stuck with 17c+.
Mods - 3" exh, pod, 1bar boost, 040 pump (pretty sure thats it now).
Overall everything feels so much smoother so im rather impressed with it all. Engine showed no pinging what so ever.
Any advice or questions shout out...
Still waiting on dyno sheets? I'm extremely interested in seeing how you can make an extra 26 rwkw without changing the fuel map significantly at peak power? was the timing the same before and after cause it's easy to make that power if you were only running 10 deg before? was the boost level the same before and after?
Do you know if the ramp rate was changed at all?
hello ppl,
i got Toshi to do a chip for my R32.
My car's got an APEXi Power Intake + 3" full exhaust with Trust Power Extreme II catback. running 0.8 bar boost.
Before:
Lethargic low end, but big kick in mid-range-top.
After:
A nice bump up in low-end torque, very very smooth revving all the way to red-line. Went for a test-drive with Toshi after the chip was in, instantly had this huge grin heheh. Friend who test drove my car after the chip was put in was amazed how linear the power delivery is now.
Conclusion:
If you're after a good tune for street, circuit & touge, Toshi's chip delivers a good performance boost @ good value. I didn't do a dyno check, but I CBF anyway with dynos. A friend of mine with an S15 has similar tuning, power delivery wise, but he had to spend lots on a e-manage, etc.
what's involved in installing one of these chips? I haven't had experience in putting chips onto ecu, but have some electrical background, and thinking about saving some money while learning how to install one, can anyone provide any info?
and yeah, I wanna get one soon, in a weeks time
MIST - Do you still have the standard R32 GTST fuel pump?
Do you have any aftermarket fueling bits like injectors or regulator?
Are the mods you listed above your only mods?
SIKCAR - It's not a matter of installing chips that is the hard part, it's the programming of the fuel and ignition maps.
You need to have extensive knowledge of how much fuel and air should be programmed to be pushed through at what loads and so on...
AND, you also need to purchase the CHIP burning hardware and know how to work with ROM editors to make the changes to the fuel maps to make it safer and some how BETTER than standard..
Good luck.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
