Hi
for those who live in sutho shire or near by places, come to the photoshoot on sunday 18th may 3.30pm at greenhill carpark (nulla)
I wont have the internet till monday most likley (changing ISPS etc), so wont be able to check this thread tomorrow onwards.
Anyways if you are free come along!!
Will be good to meet some people from the shire etc..
Got fair few cars coming already.. so should be good :D
BE THERE
Ta
Edited by siddr20
yea come bro.. tell your friends etc :spank:
Directions:
Come down kingsway, then turn left (you will see northies)
Keep going straight at the first round about turn right (Burke rd), then turn left (road sorta goes left anyways)
Now you will be going up Mitchelle road.. Keep going straight (you will see the wall on the right - so they call it).
Go right to the end of the road
Yup i have posted them on ns.com
Well not all of them..
here is the link..
http://www.nissansilvia.com/forums/index.p...howtopic=307079
I dont have the net till wednesday most likley (at friends place now).. so will upload rest of the pics when i get my net back
ta
