PRO Power FC or Power FC
Guest Calv R33 GTS25t
Hi All
Im buying a new Power FC from Japan and on offer is the PRO Power FC and the Power FC the difference is about £40.
Only thing is no-one knows the difference apart from its used for racing, this doe'snt really tell me whats different about it.
Does anyone know what extra functions it has and will they ever be of any use? or is it no good to be as I'm not going to race it!
I know you have to use the boost controller on the PRO version, but is an option to activate on the standard one.
Can anyone help me because the moneys burning a hole in my pocket, and am already looking at a bulk order of ice lollys.
Calv
https://www.sau.com.au/forums/topic/2193-pro-power-fc-or-power-fc/
The pro, in conjunction with the boost controller , is supposed to allow a sort of anti lag style launch control.
Am waiting for my mate to translate the bloody jap instructions that came with mine, then I will tell you more.
Ken
Hi Ken
This is the thing that keeps coming up, looks like you can build up more boost on a launch, back tyres will last even fewer miles!
But is it as good for general driving can you set it to run on a mildly tuned setting or even standard as this car is not used for racing.
Have you had it mapped, was it the same mapping procedure and set up with the same laptop software, I dont want to get it to the UK and find I cant get it mapped yet. Thanks for the info.
Calv
PS Ken, Any chance of a copy of the translation?
Originally posted by Calv R33 GTS25t
Hi Ken
Don't know as haven't installed yet
If you can get it mapped , then your doing better than us in WA.
Some one is getting laptop software but at the moment , it's all handcontroller only
The blokes name is Brent Richards, he's a Aussie living in Japan, his web site is www.nengun.siteblast.com you can make big savings on the UK retail prices, anyway check his sit out.
Calv
Depends on how much it's gonna cost me from the translator
Ken
The main difference is that the PRO uses map sensor instead of mass airflow meters. This means you can get rid of those afm's restricting flow, and supposedly the computer will hadle the fact that you have six throttle bodies unlike other map sensored computers. I think this is right this is what i have been told anyway hope it helps:)
So does this mean you have to get rid of your afm or will it run with or without, does your car still have its afm's inline Ken? Let me know about that translation.
Calv
No, as far as I know you have the option but using MAP with the 6 throttle bodies can , I've been told , cause some drivability issues.Translation is about 40 pages so is gonna take some time.
Ken
They use the PRO on the apexi drag cars and apexi recommend it for competition use if you are goin to use it in map sensor mode as ken says although they wont say it the map sensor still has trouble controlling individual throttle bodies. Calv you can get rid of it or you can choose to kepp them depends on the mode you run, if you do run map yes you can vent to atmosphere with blow off valve and there are no probs!!
There is an interesting thing in the latest ZOOM, saying that the Power FC up until now required AFMs, but there is now a 400 AUD option that can eliminate the AFM's.
It's in the section on comparing different ECU's. No comparisson on the Power FC Vs Power FC pro.
From what I've been told, the tuning of the Pro version can take a lot more time as there is no base map.
Can anyone confirm?
So you get no base maps? if you have to set them up from scratch and if you cant load a standard PFC map on its sounds like its going to get expensive!
Unless you are going to get a lot more power without the AFM's it sounds like the standard PFC will be the most suitable, especially if there are drivability problems anyway.
More boost on launch will probally cause traction problems as well with mine being rear wheel drive.
What do you people think?
Calv
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
