PRO Power FC or Power FC
Guest Calv R33 GTS25t
Hi All
Im buying a new Power FC from Japan and on offer is the PRO Power FC and the Power FC the difference is about £40.
Only thing is no-one knows the difference apart from its used for racing, this doe'snt really tell me whats different about it.
Does anyone know what extra functions it has and will they ever be of any use? or is it no good to be as I'm not going to race it!
I know you have to use the boost controller on the PRO version, but is an option to activate on the standard one.
Can anyone help me because the moneys burning a hole in my pocket, and am already looking at a bulk order of ice lollys.
Calv
https://www.sau.com.au/forums/topic/2193-pro-power-fc-or-power-fc/
The pro, in conjunction with the boost controller , is supposed to allow a sort of anti lag style launch control.
Am waiting for my mate to translate the bloody jap instructions that came with mine, then I will tell you more.
Ken
Hi Ken
This is the thing that keeps coming up, looks like you can build up more boost on a launch, back tyres will last even fewer miles!
But is it as good for general driving can you set it to run on a mildly tuned setting or even standard as this car is not used for racing.
Have you had it mapped, was it the same mapping procedure and set up with the same laptop software, I dont want to get it to the UK and find I cant get it mapped yet. Thanks for the info.
Calv
PS Ken, Any chance of a copy of the translation?
Originally posted by Calv R33 GTS25t
Hi Ken
Don't know as haven't installed yet
If you can get it mapped , then your doing better than us in WA.
Some one is getting laptop software but at the moment , it's all handcontroller only
The blokes name is Brent Richards, he's a Aussie living in Japan, his web site is www.nengun.siteblast.com you can make big savings on the UK retail prices, anyway check his sit out.
Calv
Depends on how much it's gonna cost me from the translator
Ken
The main difference is that the PRO uses map sensor instead of mass airflow meters. This means you can get rid of those afm's restricting flow, and supposedly the computer will hadle the fact that you have six throttle bodies unlike other map sensored computers. I think this is right this is what i have been told anyway hope it helps:)
So does this mean you have to get rid of your afm or will it run with or without, does your car still have its afm's inline Ken? Let me know about that translation.
Calv
No, as far as I know you have the option but using MAP with the 6 throttle bodies can , I've been told , cause some drivability issues.Translation is about 40 pages so is gonna take some time.
Ken
They use the PRO on the apexi drag cars and apexi recommend it for competition use if you are goin to use it in map sensor mode as ken says although they wont say it the map sensor still has trouble controlling individual throttle bodies. Calv you can get rid of it or you can choose to kepp them depends on the mode you run, if you do run map yes you can vent to atmosphere with blow off valve and there are no probs!!
There is an interesting thing in the latest ZOOM, saying that the Power FC up until now required AFMs, but there is now a 400 AUD option that can eliminate the AFM's.
It's in the section on comparing different ECU's. No comparisson on the Power FC Vs Power FC pro.
From what I've been told, the tuning of the Pro version can take a lot more time as there is no base map.
Can anyone confirm?
So you get no base maps? if you have to set them up from scratch and if you cant load a standard PFC map on its sounds like its going to get expensive!
Unless you are going to get a lot more power without the AFM's it sounds like the standard PFC will be the most suitable, especially if there are drivability problems anyway.
More boost on launch will probally cause traction problems as well with mine being rear wheel drive.
What do you people think?
Calv
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
