Another question is this event alright for stocky car???
coz now i'm broke ..... have no budget to modify :ermm:
Definately. The best way to start off is in a stock car.
It's all about the driving, not the car. I've seen pro drivers in Echo's put some hi powered cars to shame.
  • Replies 547
Posted Images
sugus, bring the cams form along and one of the club execs can sort you out for a license on the day.
stock cars go good they just sound wierd lol http://www.hgeconsulting.com.au/zoom.mpg
How about tyre, brake and so on???? Do I have to prepare anything special??? cause mine is just drivable
A handy thing would do is bleed the brakes and clean it out. It helps quite a bit.. Just make sure all your oils are topped up. Inside is clean and a wheel alignment helps too.
Ok a dumb question for all those track experts out there, got my semi slicks today, they each have respective marks on them for LF LR RF RR, so I take it they are uni directional? and obviously the tyre shop will need to put the respective tyre on the respective rim?
Hmmm I've never seen those marks on tyres before, but thats not saying its not right.
If thats what it says on the tyre I would go along with it though.
Maybe someone else can help?
I would suggest bleeding the brakes sugus. Maybe try some higher quality brake fluid too if the budget stretches. If not Just new standard fluid will work a treat.
It's looking more and more unlikely that I will be able to make it down for this - even just to watch. I've got my suit fittings for my wedding at 10am.
Wouldn't be able to get down there till around 12pm at the absolute earliest.
:banana:
:banana:
I just suggested that Jase!
P.s Elf dot 4.. Just don't get it anywhere :banana:
Yes they are unidirectional so yes the tyre shop should make sure they are put on the rims correctly.
Yes bleeding your brakes is one of the most important things you can do before the track day, as is putting an extra litre of oil in. Castrol Super Dot 4 from supercheap at about $11 will do the trick for brake fluid. If you are good you can bleed them with one bottle but get two to be sure.
Over filling the oil can also cause issues, including blow by.
Just to be sure that no one goes crazy over filling - I would only over fill by a bit past your "H" mark.
Take some oil with you if you are really concerned and check over the day.
Yes this is true and that's why only overfill by a litre and only reccomend that to others..
I am sure there will be plenty of oil around if people need to borrow some on the day.
That made no sense.
It's a pretty common recommendation for RB's Jase. More oil than usual will be in the head due to the oil pump being able to move oil up there faster than it can drain down. This is done to protect the head but it can leave the bottom end unprotected. This is why big dollar rebuilds often include restrictors in the feeds and sometimes an external drain back. It's not like it's needed 90% of the time but it's just a little precaution that is cheap and easy to do.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
