  • Replies 547
Posted Images
I haven't damaged a front bar at the track yet :banana: *touches wood* Is your car lower then standard?
As a precuation I would take the white one down instead of your nice black one..
I don't think it would really matter but it's going to get dirty if so.
So everyone ignores my misspelling of bar... :P
My car is as standard as standard comes except for my rims which are 17", but with the tyres on there I think it would probably only a fly shit of difference. However, there is some merit in taking the already damaged one... I can smash it good and proper now! :banana:
A more serious question this time...
The rims that used to be on the back of my car still have rubber on them. Except they are down pretty much to the wear indicators, maybe a tiny but on the outside of the tyre. In the CAMS book it says something along the lines of "localised wear along the inside of the tyre" is acceptable, but I think these are a little past that point. Would these be allowed or will I have to find another place to burn the last of the rubber off legally :P ? Doesn't really matter if it doesn't, the tyres under my car at the moment will pass fine unless something bad happens *knocks wood*
I'm fine if you want to use them up. I have no problems with it.
Hey I got another newbie question...
I was planning on bringing down some tools and a jack and stands just in case...My jack is a steel 2.5 tonne beast though and weighs a tonne...is anyone else bringing that sort of gear down?? I am happy to be self sufficient but then again dont wnat to bring a tonne of gear down only to find I didn't need to...
Btw I have a Consult interface and laptop if anybody else with stock ECU needs it...
Also where do we put tools and all the stuff we remove from the car....
Not that many people bring decent jacks these days. If you think you are going to need them take them down. If anyone asks to borrow them. Just remember who has them. I've had mine lost before.
Tools and other items are just left in the garages. They will be fine there.
Most days there are people there with various tools, but if your likely to need something i would bring it myslef. You never know, this could be the one trackday that everybody decides not to bring anything :D
As for where you put them, I've always just left everything in the pit space where the car sits while it's not on the track. Never had a problem with things going missing, and seeing as we're all in different groups there is always people in the pit area.
And just bring a tarp or a sheet to cover ya stuff, its all good mate :D
Oh, and bring a chair :down:
I always make the mistake of not bringing a fold out chair....and have to sit on my tyres lol
another question do you take the back seats out before you go or do you take them out when your there, and if you do take the seats out, have you been pulled over by the cops and had any dramas.
Dont bother, just add boost
How much is the garage to hire, and if you don't have one where do you get your car ready when your there?
I think its $55 for the day, im getting it cause im staying there friday night and its somewhere safe to leave the car overnight. Plus on the actual day ill have a heater going in there all day for between sessions :P
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
