Why Go From A 20 To 25
Guest trikdoutbuketofshit
 Share
  • Replies 66
Posted Images
I said..
Just a few assumptions.
you spent about $3K on getting an RB20 in to your VL.
you then spent about $2K in getting exhaust, filter, FMIC, boost etc.
and if I remember, you've run a string of mid 14's.
correct?
You said.
my car was non turbo before and i blew my rb30de up n i brought a calais with a rb20 for dirt cheap so thats how it ended up in there
i think uve mixed me up with some1 else gtst lol
I believe I didn't mix you up with anyone else..
I did however give you a 1 second better time on your 1/4
Your thread
http://www.skylinesaustralia.com/forums/Rb...ms-t199566.html
Your post in that thread.
http://www.skylinesaustralia.com/forums/in...t&p=3557915
Guest trikdoutvl
STOLEN S15 LOL hell no im not selling my vl.... i love my car and its a 1 of a kind.. id like a skyline as a second daily driver car but caint afford it :)
GTST
LOL uve completely lost me with ur copy n pasting of old threads n wat not LOL...... wat are ya trying to say man lol.. ill get my part clear LOL
heres the story of why i brought a rb20
MY rb30 na motor had a bottom end knock was stuffed
brought a vl calias wit the 20 in it with a blown diff for dirt cheap
put the 20 in my white vl i got now already had cooler and exhaust
put the f*kd 30 (still ran) in the calais and sold the calais for a decent amount
so i pretty much got a rb20 motor nearly for free only cost me to get it installed
there was no way i could have gone 25 for anywhere near wat it cost to go 20 cause i would have had to buy a half cut n made no money back on it....
i havent even spent 5 cents makeing the motor go faster except for getting a hi flow cat cause mine was blocked
Guest trikdoutvl
chris r31
HAHAHAHAHAHA f*k yeh that vl is off its chopssssssssssssssssssssss lol rb20 power
Guest trikdoutvl
the engines the tip of the ice burg tho in cuztomness
so 1 of a kind stands :)
Edited by trikdoutvl
Rb20's are strong as f**k on standard internals, CHEAP and reliable. You do need to rev them a bit to make power but its not too bad. I still love mine.. Roys car is a good example, good power on a big turbo and not too much lag.
Of course the Rb25 is naturally a better motor (how couldn't be with an extra 500cc?) But they are still fairly expensive($2000+), not to mention if you put one in a R32 you will need to upgrade to a rb25 box (another $1500) as it will destroy the RB20 box with ease. Theres also the hassles with the driveshaft, speedo sensor and sorting out the wiring and gearbox mount.
My opinion - If I had the cash I'd love a RB25.. but I'd rather spend it elsewhere on the car, so I'm happy with my little RB20 which sees limiter daily and doesn't complain! - Don't forget it sounds f**king awesome doing it :)
Lol you only say that because you have such a N/A sohc anchor in your boat of a VL.
RB30E over RB20DET? If i blew up my rb20, i wouldn't put a NA rb30 in even if someone paid me.
Guest trikdoutvl
IVE BROKEN 3 RB30DE'S
2 IN VLS
1 IN R31 SKYLINE
ALSO I USED TO OWN A VLT WITH A RB30ET JUST WITH A HI FLOW MADE 270HP WAS COOL BUT MEH ITS STILL A RB30 WENT HARD BUT IN THE SOUND DEPARTMENT THE 20 SOUNDS MUCH NICERS TO ME 25 SOUNDED SIK AS WELL DOESNTT REALLY SOUND THE SAME AS THE 20 THO.,,,, CAN MOST OF USES PIK THE DIFFERENCE IN SOUND BETWEEN THE 20 N 25???
GTST
what's to be lost about.
your old thread says that you spent $5K and are now running 15.7 on the quarter at best.
it also keeps asking if we think the video sounds good.
you hadn't mentioned that you sold all the other bits off and made your money back.
what I was saying was that the $5K you initially spent to buy the other VL, transfer the 2 motors over etc etc only to run a 15.7, you could have gone MUCH MUCH faster for that $5K by rebuilding an RB30e and adding a turbo or doing a budget RB30/25.
Guest trikdoutvl
then i would have had nothing to sell to get my money back,,,,,, goin the 20 was the cheapest way of going turbo,,, aint a millionare n i dont have the time to f*k around building a half breed motor.... car was only off the road for a few days to 20 it........ dissicusion pretty much passed cause the 25 vl is sold anyways
i just watched a vl rb20 run a 12.5 1/4.... im in love lol
is this thread a joke....... why put a 20 in a vl......i love all rb's but dude a 2 litre in a heavy commonwhore is madness.
james????
dude, are you awake, those 1987 holden commodores are lighter than a r32 nissan skyline,
my question is why go 25 when for 5 g you could go rb26dett?
Edited by nizmonut
ENOUGH SAID!!!!11!!!!11111!!!!!!!!!
YOMFGWTFBBQ
street skids are sick!!!!111!!11ty
I Idol this guy so much.....wait..no :D
My question...Why buy a VL in the 1st place...worst Holden ever built (diesel Gemini Included)
 Share
    • Hello, The dog bone wont have much to do with this - the calliper applies a load about the disc - the outside of the calliper is more flexible than the inside by virtue of it not haveing the big torqued down bolts, additional metal structure on the caliper itself, and mostly not being cantilevered. So the outside of the calliper is pushing away as its more bendy and brining the inside with it as an equal pressure on both sides of the caliper looks to cause more flex on the outside - which makes sense. I have done this same thing with the calliper unbolted from the dog bone - same thing happens. Although id have to watch more carefully to see how much more the outside moves than the inside in this case. Im guessing there is a point in the pedals travel where the pressure is not actually increasing in the system - its just volumne displacemnt - and because the outside of the calliper is more flexy, it receives that volume. Have gone back to Alcon again - but beyond a resolution there I would stay clear of this calliper and possibly any of the lighweight type of callipers - especially if you have the smaller 15/16" master cylinder. Cheers.
    • Yes, you can very clearly see from more than one angle that it is the whole caliper moving left-right, not deformation of the caliper. The top moves, the bottom moves. Equally. It should be possible to see where the movement is occurring. Just need to look more closely.
    • Hi Folks, my 2009 Skyline 370GT “Crossover” wagon is losing water and has been diagnosed as needing a water pump replacement (it’s an internal timing-chain driven unit, not the usual electric type that seems to be used across many manufacturers). Am looking for any repairer recommendations in the Sydney /Wollongong region who can be trusted and are experienced in this sort of work on the VQ 36 engine. Many thanks….Bill
    • While all of the above makes sense, we're not talking about some Ling Long calipers of AliExpress; Alcon would have to be one of the top 5 caliper suppliers in the world and these are not their budget units. If there were manufacturing defects in the caliper causing this issue I'd be very disappointed. Having re-watched the video a few times I think it's dog bone/mount related. The caliper moves independently to the rest of the suspension and brake assembly which suggests to me that it's not mounted rigidly. I know this sounds stupid, but have you got enough thread on the retaining bolts or are they a poofteenth too long and it's not super tight? For axial movement to be occurring without deforming the caliper that can be the only answer.
    • Extra torque will wear it out. The clutches won't be to the same spec as those on the turbo box, and the shift speeds possibly won't suit handling more torque either. Autos in R34s are a nightmare. 8HP conversion is the only sensible option.
