What brand;
Autometre ( are they accurate but? )
Spitfire ?
VDO
Actually I want one with a black background but with green dials and numbers. ? is it called ****pit vision or something?
What should I be paying for it and how much do they charge for install. Or is it easy and can u do it yourself ?
Thanks
Guest RedLineGTR
How much do you want to spend thats the thing...most people got for autometre ones they are cheaper and look better than the spitfire and VDO gauges. The Auotmeter ones are heaper than the jap brands but i personlly dont like the look of em i rather pay abit more and get jap one with some style some people are happy with the autometer ones, depends on your own personal choice. Cheers Rob
Depends on what your after.
I got a VDO boost and oil temp in mine cause I wanted the factory look.
Everyone said that the VDO boost gauges weren't very good, but when I had my car on the dyno the boost gauge was out by 0.2psi at 12psi (dyno read 12.2psi and boost gauge said 12psi) !!!
I think that is pretty good for the $125 that I paid ;)
J
Guest Boxhead
yes it comes down to how much you want to pay, i know my boost gauge is very accurate, on dyno it read 12.55 psi and gauge said just in between 12-13 psi...
im happy, it does the job, personally, i rekon its best to keep an eye out on the forums etc might get one cheap, or go to an import wreckers, they might have what your after... as i have asked one place, and he said they get them all the time, but just didnt have any atm coz there waiting for next container to arrive...
by the way i have an autometer
Do u think I should get an oil pressure one aswell, since I only have a stock one on the dash at the moment.
If I buy one, it might be more accurate than the dash one ?
my car is standard at the moment, do u think I would need an oil temp one or maybe a voltmetre might be handy.....I was thinkin about riggin them up under the stereo...
No pillar mounts as they are illegal so I heard
Swordfish, just for your reference, this is my din gauge setup..... a boost gauge is going in where the factory clock is and i'll be moving the climate control down the bottom and the gauges up to the top in a few weeks (wire lengths permitting - finger crossed!)
i've got a "swoosh" gauge that cost me $80 new, when tested on the dyno it read about 1psi more than the dyno gauge, works for me :(
Swordfish19792002: piller mounts r legal as long as there below the top of the steering wheel.
Guest Boxhead
not cheap at all... and also they are electrical, therefor you need controller which i have heard is around the 400 ish mark alone...
go the glovebox set up :( stealth, and when car is parked, no one will see gauges, and go, smash window rip them out...
  • 2 months later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
