A friend has a T3 turbo off his vl rb30det. He offered it to me for $350. Is this a decent upgrade for an rb20det and do you think this is a reasonably price?? It should be a straight bolt on shouldn't it? Anything in particular to look for with the t3's besides shaft play? All comments appreciated.
Thanks
Jase
https://www.sau.com.au/forums/topic/21965-t3-for-rb20det/
yes just a plain thrust bearing (not a bb) water and oil cooled.
and yes bigger than rb25 turbo.
might be late 80s technology but still make the power to show most of u boys up. dont knock em.
mase
check especially around the wastegate hole (these turbos incorporate an internal gate) check around the hole for cracks in the housing itself , i can almost garauntee there will be tiny ones , dont worry about it. unless it is quite apparent.
shaft play isnt too big a drama , there will be some play , every turbo needs a wee bit of play , if its over the top then it may be worn internally.
t3s seem to be quite a good turbo , if it hasnt been pushed beyond its working limits of about 12 psi ,and has had regular oil changes, then internally it should be good, buy it , hiflo it and have fun , will be a bit laggy on a rb20 but itll be good.
https://www.sau.com.au/forums/topic/21965-t3-for-rb20det/#findComment-468830
i had one on my RB20 for a few weeks, was a litle bit laggy compared to a RB25 turbo, but you can safely run them on 15psi all day without fear of the ceramic turbine blowing apart. Made more power then the standard RB20 turbo, so go for it, 350 is cheap and you will easily get your money back if you wish to sell.
https://www.sau.com.au/forums/topic/21965-t3-for-rb20det/#findComment-468875
Hi guys, I have never seen a T3 equiped RB20DET make anywhere near the same average power in the RPM range from 2,000 to 7,500 rpm that a RB25DET turbo equiped RB20DET does. If it was my money I'd spend a couple hundy more for a 15 year younger turbo with balls and water.
Later on, ball bearing high flow it for 210 rwkw with an average from 4,000 rpm to 7,500 rpm over 170 rwkw. I've never seen a T3 make anywhere near that either.
Don't get me started on durability, plain bearings and thrust plates = lots of servicing. That's why Nissan went to balls and water, to get away from the servicing costs.
Hope that adds to the discussion
https://www.sau.com.au/forums/topic/21965-t3-for-rb20det/#findComment-468955
yeah thats a fair point sydneykid, i have a 25 turbo on my RB20 at the moment and it has a shitload more mid then i can remember the T3 had on my RB20 a few years ago. But that was with a standard computer compared to a haltech now with the Rb25 turbo.
You are right about the plain bearings and thrust plates needing a regular rebuild, but i reckon it would last longer on 1 bar than a 25 turbo would
https://www.sau.com.au/forums/topic/21965-t3-for-rb20det/#findComment-468988
My understanding is that bush bearing turbos are more succpetible to oil quality (So stick with top quality oil, and changing at regular/frequent intervals) and they only really start to hurt when boost is wound up.
Sydneykid, im not going to claim they are equal let alone superior to a BB turbo from a durability perspective, but they can be reliable. Also many of us run stock internals so will never really every wind up boost meaning the bush/thrust plates wont see high loads or wear.
Nor am i suggesting Mase but a 17year old turbo, just trying to point out that sometimes a plain bush turbo can meet the demands of a street driven car, especially if $$$ are factored in.
https://www.sau.com.au/forums/topic/21965-t3-for-rb20det/#findComment-468991
t3 are water cooled my man
i have over 200 rwkw , mind u its a 3ltr.
if u keep up with oil changes etc , as i do every 4000k , i dont mind paying for a few more bottles of oil per year , then u wont have too many dramas with it.
https://www.sau.com.au/forums/topic/21965-t3-for-rb20det/#findComment-469107
Just remember Trust turbos have no water cooling and plain bearings, and they are based on truck turbos.
I wouldn't touch the T3 with a ten foot pole unless it's been rebuilt recently, otherwise you have a very old turbo. Otherwise no problems.
https://www.sau.com.au/forums/topic/21965-t3-for-rb20det/#findComment-469352
The rb25det upgrade on a rb20 doesn't do much at all. Ive seen a few put on rb20's and they get like 8hp max. Thats *** all.
I hi flowed the rb20 turbo with a sierra cosworth rear wheel and v-trim front wheel and put a vg30 compressor housing on which is slightly bigger than the rb20.
Power went up 50hp. FUll boost by 3800. Which is pretty good for a 20.
https://www.sau.com.au/forums/topic/21965-t3-for-rb20det/#findComment-470511
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
