Hey
Upgrading turbo again on standard RB20 motor just wanted to know what would be a better option
I can either go with a Apexi AX53B70 or HKS2535 - both turbos in similar condition, for similar price and both come with split stainless dump pipes and braided lines
Anyways its not the cost I am worried about its the better suited turbo for the RB20
I am chasing around 230rwkw and have the following mods;
Apexi Power FC
Apexi AVCR
Blitz Intercooler
HKS adjustable CAM gears
GTR injectors
3" turbo back
BOSCH 040
I have seen a internally standard RB20 making about 230rwkw with the Apexi AX53B70 turbo but not sure on what boost and I'm aware there are a few members with standard RB20s cracking 230rwkw + with the HKS2535 on around 19psi
Anyways, I'm just after a comparison of the two and wondering whats a better suited combination for the RB20 with my supporting modifications
I'm aware the Apexi AX53B70 is rated at 370ps but whats the HKS2535 rated at, I've heard mixed responses
Any advise or past experiences would be appreciated
Thanks
https://www.sau.com.au/forums/topic/219678-apexi-ax53b70-or-hks2535/
abu i believe the apexi is rated at 420hp?? correct me if im wrong...
just rememebr i think the apexi still runs the ceramic rear wheel! so i have read 18psi is max??
with supporting mods they have seen to make 250 on an rb20 so plenty more for u!
as i have the same setup besides cam gears im looking at 220-240kw! but u will prob find the cam gears to help with some response!
good luck with ur choice!
cheers
dont like your current setup? I would try the Apexi turbo myself. The results i have read with them are at least line ball with the 2530, and could be Just be sure you get the right housings, not the P22 etc as that sized housing would be overly laggy,
Also re the 230rwkws, it makes for a quick car. But the lag at 230rwkws isnt too different from the 450hp style turbos that will bag you 250rwkws with just about the same amount of response. You arelady have the injectors etc
I had a AX53B70 P25 on my 25 and made 20psi by 3000rpm and 253rwkw my tuner often commented it was the most responsive turbo he had ever tuned , i would try it but check the exhaust housing around the wastegate hole, they can sometimes crack there
Having a 2535 myself i would say its a good thing...but funnily enough i was thinking of going with the apexi turbo with the rebuilt engine...
From the results i've seen on here they seem to be pretty similar...the 2525 is rated at 340ps from memory...but it probably makes abit more than that...personally i'd take some time and just pick the one which is in better nick...
well driving mine in the last 2 days i have found mine is hitting 10psi but about 4500-5000k which i think is abit high???
any ideas y??
Probably just needs to be tuned but thats still quiet high.. my T04e made 1 bar (14psi) by 4,500rpm and 18psi by around 4,700rpm
You have supporting mods I assume, cooler, turbo back exhaust etc?
I have used 2 Apexi AX53 turbos on my SR20 and had awesome results HOWEVER I have seen many of them failing due to the compressor wheel hitting the front housing and mashing the blades. This happened to both of mine and at least 3 others here in SA and they are unable to be rebuilt as you cannot obtain Apexi parts for them.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
