  • Replies 504
Originally posted by GTS-t VSPEC
PAS will be more crowded than Autosalon, but next year they'll be a new and much bigger venue:D
Kyles/Niz, I'll chat with the t-shirt chick and see what I can sort out for you in the way of a dark blue singlet:D
Hey Paul,
I have been sorted disconnected with most of the setup for PAS but when is the next meeting for all those concerned?? What the theme that has been selected?? and do I need to put some bids in on T-shirts, will need one fat and one extra fat. The girly and me will be there and she is also happy to help out, she has very large assets :P hehehe, hear from you soon
Cheers mate
:headshot:
Hi Danny, We'll have another meeting at the PAS dyno day on the 5th. Flyers have been sorted, hopefully we have a banner coming, t-shirts are being sorted. The theme is a racing one. We sorting out PS2's and a competition, and we hope to have a DVD with footage from club activities:D
Paul not meaning to be difficult but singlet for Kyles .... the other shirt for me .... didnt really like the singlet and its too low for me to "fill"
yeah i know we're fussy. :D
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
