I was at the Drifts on Wed night and I got some good photos of a car on fire
Check it out!!!!!
Lucky there was enough fire extinguishers there to put it out
The Car had a fuel leak and it was nearly lost lucky it was not out on the track at the time
Was anyone there??
Cheers Craig
Dam the picture is 3.25 MB
Cant post it up as yet because of the 2MB limit
Will try to post it up later
https://www.sau.com.au/forums/topic/219840-flame-on/
It is right hand drive
He was reaching for the fuel cut off it is mounted on the left hand side on top of dash
You should have seen the first flame is was so big it extended from one end of the car to the other
It was put out very quickly but the fuel kept pumping and fueling the fire
I took plenty of shots
No one was hurt thankfully but it did add some excitment to the night!!!!!!
https://www.sau.com.au/forums/topic/219840-flame-on/#findComment-3880260
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
