Hey guys i know its probably been asked before but i cant find anything specific in the search. i'm currently putting a rb20 into my 92 bmw. so far the mods for the motor are r33 turbo, custom intake plenum, front mount short plumbing, 255lph fuel pump, remap chip for the ecu. what i'm aiming for is about 300horsepower at the wheels. What other mods am i gonna need to get close or over my power aim, like bigger injectors or after market exhaust manifold, cams etc. i'm gonna run about 15-16 psi everyday and eventually forge the motor. any help appreciated cheers
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/
15-16psi on stock RB turbos = Epic fail 12-13psi is a safer (slightly) option
and from what ive seen rb25 turbos on rb20s will make around 200rwkw. 300hp is 225kws.
post up some pics of how it fits as ive been wondering about a conversion of this sort for a while.
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3884588
the reason for rb20 is for one cost to start with and if/when this motor fails it will be getting a fully forged rb30det(rb25 head). and for now the 2 litre keeps my insurance down as i'm already payng heaps for a euro car. As for the turbo i will post pics of my mates bmw with an rb20 which is running the standard rb20 turbo and has been running 15psi for the last 18-19 months with no problems/smoke. The turbo willbe staying as is for a month or 2 till i can upgrade but my exhaust will be very custom so i'm chasing a turbo that will fit both my t3 flange manifold and the dump pipe
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3884650
Yep you might get away with around 14psi since its on a 20, few people have and most you will see is 18xrwkw on an internally standard 20 thats in pretty good nick with supporting mods
I would suggest a second hand high flow if your not looking at spending a great deal
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3884692
kool thanks guys might run 14 to start with till i get my hands on a second hand hiflow. any tips on where to find one/suppliers? the reason i was thining around that psi is mainly because my mate has been running 15psi for 18 months racing/ draging the car and has not had the turbo fail and it is only a standard rb20 one
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3884894
pffft 15psi is safe lol, yeh run 15 through it, then dont complain when the rear wheel falls off, and the front wheel then chews into the housing shattering the wheel putting metal peices into your intercooler or into your engine...
just do what is suggested... 12psi and save up for a highflow that you can push 18psi through.
maybe its just me, but id rather do things right the first time, even if your on a budget (even more so if your on a budget)
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3885572
the rb25 turbo isnt ball bearing is it? what other turbo's of standard cars will fit and be adequate? dont want to pour thousands into the turbo setup
rb25 turbo is ceramic, and isnt ball bearing unfortunately.
they cant/shouldnt take more then 13psi (11 to be uber safe)
as suggested, try the hi-flow option, or the hks 2530.
cheers
eddie
R33 turbo's are BB, i know this because i was told they were not and went out and bought a bush bearing rebuild kit for my S1 turbo only to discover once we got the turbo apart that they are actually a GT28 as opposed to the T28 which is a bush bearing.
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3885790
You will be able to run slightly higher boost with the rb25 turbo on an rb20 rather than an rb25 because of the engine capacity.. I did say SLIGHTLY higher tho.. :D
edit: i do agree you will probably struggle to get near 300hp with this setup..
Edited by nitestalkr
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3885937
Actually there a hitachi turbo not a garret....so they aint t28 nor gt28
Thats just basicly a rough size estimate that is given to them (the stock turbos)
obviously the turbo is the same as a garret then since MTQ use a T28 rebuild kit for them.
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3886045
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
