  • Replies 141
I bet you dollars to doughnuts if he really did spend the day at the track it was as a spectator not actually getting out there having a go. anyone I know after a full day of circuit racing, or drifting is absolutely knackered after a days racing and you would most definitely be driving sedately home again.
Werd!
You would also have to question how a piece of sh!t help together by cable ties would ever pass scrutineering.
drifting is not so worried about the securing of body kits, though the battery would definitely have seen him sitting that one out. all in all I say he was some clown who went to see some people with actual balls have a go at drifting or racing. being too much of a pussy to participate himself he thought he would make himself feel more manly buy thrashing the nuts out of his shitbox on the way home.
He's a tool, granted.
Hope he gets what he deserves.
But what really shits me is how the journo makes it out too the average joe that the doors or bonnet were held on by cable ties and the notion of taking out a back seat is so foreign to them that it must be pure evil when majority of us do that for track day too.
The battery thing... I got nothing and I've had a battery ground itself when cornering and explode.
very true - especially at QR in summer :sweatingman:
there is a rumor at work that this was me :rofl:
All because I have like 2 cable ties on my front bar until I can fix it.
oh and because ppl that are apparently "car enthusiasts" don't know the difference between a 200sx and an R32
lol, you're the first person I thought of when I heard this on the news this morning!
Except I KNOW that you're not stupid enough to attempt this on a public road. :P
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
