  • Replies 141
this reminds me of myself, it was about 2 am on sunday morning on a big downhill straight on the freeway,well highway between branxton and singleton, i recently got my car up to 200km/h. i guess 263 is alot more then 200. and of course i don't drive a nissan turbo, but i'm sure in the market for one, r34 gtr or r32 gtr. i was going to go with a gt4, but i might as well go all out.
Sorry dude, but i think you are stupid and I hope someone else manages to take you off this planet before you have the chance to kill others
Population control for people who think like the above, you don't need a skyline, you need a bicycle or skateboard
this just makes me want a skyline even more, stupid p's plates and nsw.
well i only really want a skyline to smoke v8 bogans.
don't say you haven't.
Wrong forum are you mate.
try here
www.nissansilvia.com
Or This One
www.ibuyaskylinetobefullysicklikethorpie.com
NUB
how high do you get from smoking v8 bogans? you sound pretty off chops....
heaps sick aye bro lets use the road as a racetrack and do stupid speeds, its people like you that have made the RTA do what they did, i cant imagine the stupidity youd be getting up to if you had a more powerful car....
Take your car to the track if you want to go fast, there are no powerpoles, cars, cops, or people to slow you down if you come off... and no one to hurt apart from yourself
Reminds you of yourself? You my friend are a Grade A moron... Grow up
Interstingly, did anyone here about that guy doing 170 on windsor rd and killed two women the other day?
I heard about that. Is really tragic. Ambo driver came into work and told me bout it. Feel sorry for those involved, and people havin to clean up the mess. too many people too selfish to realise they put others at risk too.
Apparently he stole that RX8.. So he's in a world of f**king shit when he comes out of there.
He WILL do time.. It's just a matter of how the judge views the case.
I think 10 years + for sure.. I'd like to see life, but, with the system these days he could probably get below 10.
Edited by ignuz
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
