I think you would have to change the whole front to S2. Because for each item you change, it won't be compatible with your other S1 item.
ok if anyone else have info on this let me know please cause i want to put series 2 front bar and bonnet on
https://www.sau.com.au/forums/topic/220592-bonnet/#findComment-3890571
the S2 bonnet might fit on pending whether or not you can close it
cause the S1 headlights are bigger than the S2 headlgiht
thus that implies that the S2 bonnet will have a tight fit around S1 headlights
I've got S1 headlights on my S2 and only had 2 modify the grill,
need to use a lil gentle force to close the bonnet as well
https://www.sau.com.au/forums/topic/220592-bonnet/#findComment-3890655
Any pics of the frount end of your car :( sounds kinda funky :P
https://www.sau.com.au/forums/topic/220592-bonnet/#findComment-3890874
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
