Skyline Parts (r32 & R33) & Random Car Parts
Item: 1x Nankang Ulta Sport Performance tyre 254/35Z R19 (19")
Item Condition: Brand new, never used
Price: $70.00
Item: 1x Skyracing tyre P215/65 R16 (16")
Item Condition: was in boot of my old commodore
Price: $30.00
Item: 2x R33 Nissan Skyline Castor Rods with bolt & nut
Item Condition: Used, off half cut with 70***km
Price: $20.00 each
Item: 1x R32 Skyline Drive Arm (From diff to hub assembly)
Item Condition: Used, has been damaged
Price: $5.00
Item: 1x R32 Skyline Rear Left Hand Side Hub assembly
Item Condition: Used , includes rotors suspension arms, stock & spring & drive arm.
Price: 70.00
Item: 1x R33 Skyline Standard Genuine Nissan Dump Pipe
Price: $30.00
Item: R33 Skyline Air conditioning Parts
Price: $100 for all parts of 35.00 each
Item: R33 Skyline Standard shocks & springs with tops
Item Condition: Used, out of half cut with 70,***km, no damage
Price: $40.00
Item: 1x R33 Skyline Side mount intercooler SMIC
Item Condition: used, includes all piping etc..
Price: $35.00
Payment Conditions of all items: Pick up, or postage at buyers expense :P
Reason for Selling all items: Garage clear out :(
Location of all items: Hame's Garage, Carindale, Sth Brisbane
Contact Details: PM, [email protected], or 0419761510 (can't recieve txt tho! :rofl::down: )
  • Replies 69
Item: 1x R32 Skyline Viscious Differential (VLSD)
Item Condition: used, but perfect condition
Price: $120.00
Item: 1x R32 Skyline Rear Sway Bar
Price: $35.00
Item: 1x R32 Skyline Green lable AFM
Price: $70.00
  • 1 month later...
  • 3 weeks later...
Turbo no longer for sale, hubs payment has fallen through so they back up for sale and there has been many offers on the brake calipers but no pick up as yet.
I will grab castor rods if you still got them and they are not leaking or no major cracks...
Give me a PM on full price to Melbourne - 3037 and your number.
Then we can organise payment.
cheers
Hey there bluey 33, will check the condition of the castor rods and get back to you.
Rear seatbelts have sold on - boostcrusing.
Front 2 x brake calipers also sold on - boostcrusing.
still plently left, hame
Can't edit first post so here is some more parts guys!! http://www.boostcruising.com/forums/index....howtopic=300288 (for pics etc)
r32 BRAKE CALIPERS SOLD, DIFF IS SOLD PENDING PAYMENT & THE r32 DOOR SEALS SOLD.
Item: 1x Apexi AFC
Item Condition: used, suits any japanese import. This is the original air fuel converter from Apexi
Price: $40.00
Item: 1x R32 Skyline chrome front bar garnish
Item Condition: used, gneral wear and tear, chrome
Price: $30.00
Item: 2x R32 Skyline GTS-T Rear cradle mounting brackets
Item Condition: used, no bending
Price: $20.00
Item: 2x R32 Skyline GTS-T rear suspension stabelizers
Item Condition: used, general wear and tear, bolts included
Price: $30.00
Item: 2x R32 Skyline GTS-T Rear cradle corner weights
Item Condition: used, great condition, bolts included
Price: $20.00
Item: 2x R32 Skyline GTS-T Rear Seat Belts & Buckles
Item Condition: used, perfect condition, no wear n tear or rips.
Price: $50.00
Item: 1x R32 Skyline GTS-T Turbo Heat Shield
Item Condition: used, great condition, bolts included (if i cant remember where i put them!)
Price: $20.00
Item: 2x R32 Skyline GTS-T Rear Brake Calipers
Item Condition: used, great condition, bolts included, these items are off an r32 gts-t 4 door (1989)
Price: $100.00
Item: 2x R32 Skyline GTS-T Rear Brake Rotors
Item Condition: used, plently of meat left
Price: $35 each or $60 for both!
Item: 2x R32 Skyline GTS-T Window Rubber Seals
Item Condition: used, great condition, not perished or cracked suit 2 door.
Price: $40.00 SOLD
Item: 1x R32 Skyline GTS-T Boot Rubber Seal
Price: $20.00
Item: 1x R32 Skyline GTS-T 93 model turbo exhaust manifold
Price: $25.00
Item: 1x R32 Skyline GTS-T 94 model turbo exhaust manifold
Price: $30.00
Item: 1x R32 Skyline GTS-T 93 model Side Mount Intercooler (aftermarket brand looks thicker)
Item Condition: used, great condition, no leaks
Price: $25.00
  • 4 weeks later...
1x R32 Skyline GTS-T ECU (manual-turbo) SOLD
more parts added & picutres of parts here --> http://www.boostcruising.com/forums/index....entry1283018402
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
