Gday everyone, this is my 1st post.
im seriously thinking of getting a R33 GTR.
What would be needed to get the car into the 11-10's 1/4mile ?
I have a very lame knowedge of skylines and have been a holden fan. Currently owning a VXSS tricked up and it runs a 12.2 on streets. but being 22 i need more. i want to see 11 to 10's and its getting time to sell the VXSS.
How much money would need to be spend on the GTR to see 11's ?
and whats a good imported R33 GT-R worth ? im guessing around 45?
any help would be AWSOME !!
thanks
MELV
https://www.sau.com.au/forums/topic/22066-help-getting-a-gtr-r33-into-10s/
  • Replies 56
A guy on this forum has a R33 gtr running ~10.4sec 1/4 miles
Name is Leewah, give him a PM and ask about the cost. My guess is about another $25-30k after purchasing the car. This would be a quality job that is still drivable
the r33 gtst that they use is up for sale for $40 000 something i think which seems like a lot cheaper way to do it to me, they also said that the car is capable of alot more but there not touching it cause its for sale its 400hp at the wheels its suppost to be the fast 2.5 in the country at the time
if you dont get much out of them try tony rigolies work shop i dont know where they are but the deal with some serious cars and they have a shop in sydney and on the goldy they have an r33 gtst that there trying to get 600hp at the wheels out of with similar upgrades good luck
400hp at the wheels is what I've got now with the NOS kit.
MELV
Well with a GTR you first have to decide what target you want. Do you want 11's, or do you want 10's
There is a HUGE difference and cost between the two.
Also a GTS-T is NOT a GTR, so dont compare the two....anybody.
its like saying "my mate bought a torana and did it up for a full cost of $50,000 and it ran 9's", and you spend 50k on a GTR and you get a clean stockish GTR.
If you want a clean GTR, a friend is selling his 33. Pm Leewah, or SIRVROOM.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
