  • Replies 70
last night about 9pm in moorabbin (chesterville Rd) i saw a white S2 R33 gtst Slamd into a poll it happend about 5mins before i went passed. was it anyone off here?? if so how did it happen??
Thats no good . Hope it wasnt 1 of ours.. Them pole can stuff up your whole weekend..
The guy that crashed is my friend, he's perfectly fine (thank god for airbags). He walked out without a scratch. What happened was the road was a bit slippery, car went on boost and kicked out, the guy didn't manage to recover it and smacked into the pole. I think he panicked and hit the accelerator instead of the brakes (I didn't want to get into too much detail with him).
They were on the way to go go-karting and thats when it happened. The thing is, the guy is 24, off his P's and only had the car for a year. I think if he was a hoon and practiced drifting, he would've recovered it, but i suppose shit just happens. The car is a complete write-off but i suppose the main thing is that hes fine and the night didn't end with us having to call his parents.
lucky for your friend, dam makes me think i should take some of kevs clases i got off my Ps and im 22 and reciently started to drive my skyline around allot more dont want some thing like that to happen to me but i done hoony stuff befor but doesnt make me a pro lolz,
How much of a difference would have AWD vs RWD in a situation like that helped? I've almost spun out in my car on rainy nights even driving pretty sedately, but I haven't driven a RWD Skyline in the wet before. Would the transfer of torque in that situation with all the tires already losing traction actually help much?
who was the dude wif the auto 33?? APS GTS i think the number plate was??
ATP GTS, his name is Adam, good friends with the guy who crashed. He was already at the go-kart track (i think) when the other guy crashed.
Advanced drivers course would definitely help. Driving a R33 gts-t in the wet is a nightmare. In the wet around corners hyundai excels get away from me lol, the back just steps out of line. (probably has a lot to do with my crappy suspension, but I'l definitely get into one of the driver dynamics courses, just so i can get some tips on safer driving in the wet.
ohh k kool... yeh i think i saw him at the track when i was der.. then i left and seen the crashed R33
Lol dude learn to not berry the right foot :(
Lol dude learn to not berry the right foot :D
Yeh there is definitely that, but it depends on what kind of road you're on, what kind of suspension you have and what type of tires you have. In the wet, i don't bury my right foot, the car slides on its own alot of the time (not powerslide), and the whole boost thing duznt make it any easier. But thanks for the constructive criticism. ;)
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
